How to conect to USB an old MD
fedestigliano
Hi,
I have an old Sony MZ-R55, and can't buy a new one. Is it possible to conect my MD to the USB port so as to download mp3 on it? Even if it's not mp3, at least to download music easily, because I don't have any hi fi with the Optical port, and the quality of the analoge port is not so good....
Can anyone help me!
Thanks!
Edited by Cabriola
Which model wuold you buy... second had obviusly. I saw that there are some models with radio... like: sony MZ-NF610.
At the same time, you might also find a second hand NetMD for a decent price from Ebay or the classified ads ...
EDIT : Sparky191 was quicker than me on this ...
Thanks for the advise... but how does it work (practically). I've read what you send me... but I'm not so good with english...
One of these might do the trick:
http://www.dansdata.com/xitel.htm
Should be able to find one on eBay for a decent price.
Basically I'd get the newest one that the cheapest! Only problem with used units if that the lasers can go. Which is a small risk on older units. So try to get the newest one you can.
A local store to me is advertising a MD for €59. Thats old stock, but new.
http://www.xtravision.ie/xvContent.asp?id=71
In the add it shows NF610 but the text says its a MH700. I'll check it out for you can confirm which one it is. If its a MH700, I might pick up a 2nd unit for myself.
It's not bad that one, isn't it?
The only problem is that i'm in Italy... do you think the can send it here?
