MZ NH-700
Rogmur
Greetings Forum Members
I just wanted to know if any other Forum Member
has experienced reliability problems with their
Hi-MD Player/Recorder.
Sadly, and fairly recently my MZ NH-700 packed up
with out any warning.
Were the first generation Hi-MD Players unreliable?
What newer Hi-MD player/Recorder should I consider as
a replacement??
I would be very grateful for any advice.
Kind regards
Rogmur :(
The only problem I've had with a first geneation was self induced, other than tht my 2 NH-1's have been faultless. My next will be an RH-1, I'd skip the 2nd gen altogether if I were me, If I were you I'd try for another 700 or 800, or save a bit and go to an RH-1.
BTW what happened to the 700, a repair shop may be able to get you going cheaply
Take care,
Bob
I would say the first generation is extremely sturdy.
About a year after I got my NHF800, the Australian closeouts on the NH700 began and I bought one, figuring I would have another unit if anything happened to my NHF800. Since then, I have used the NHF800 for music recording 3-4 nights a week as well as speech recording. I have dropped it on hard floors. I've carried it in my pocket and my car as a player. I have worn off the lettering on most of the buttons. And the thing keeps going. The NH700 is still in mint condition because I haven't needed it yet.
I fully agree with BobT. The second generation units before the RH1 seem like cost-cutters rather than improvements. Snap up another NH700 if you're on a budget.
Many thanks
to you all for your helpful advice,
(regarding a replacement for my defunct MZ NH700).
I had thought about buying the NH 710, but perhaps
the RH-1 would be a safer bet.
Happy Christmas to all Forum members
Kindest regards
rogmur
Edited by Rogmur
I have 2yr old NH700 which I bought 2nd hand, and I've had no problems with, and I've not been that careful with it, but its still as new. Which is surprising as with its plastic construction I thought it would have broken by now. Unless I got a 1/2nd gen unit very cheap I think I'd just go with a new RH1 myself. But if I got a good deal on another unit I'd be happy to get one, just as a back up.
I am finding my NH-900 to be unreliable under certain known circumstances. When doing a single recording operation to 80 min MD media in Hi-LP mode, and reaching the full disc capacity, frequently all recorded data are lost. :( I think this is probably some flaw in the firmware.
a replacement??
Personally, I would buy another! (if you can find them)
Just curious if you dropped it
Left it in the sun/cold?
Played dusty discs in there (particularly dust on the shutter section of the disc)?
Mistreated it in any way?
My 2yo MZ-NH700 is still going good (aside from the classy silver paint peeling off so elegantly (ehm...)
