eveningsong Posted January 8, 2007 Report Share Posted January 8, 2007 Hi Folks, wondering if anyone can help? I have an NH900 HiMD that somehow has lost a casing screw. Its the top, left side which helps to hold the 'carriage' inside. I have tried everywhere but no luck so far. I am in the UK.Thanks in anticipation Quote Link to comment Share on other sites More sharing options...
milomind Posted January 8, 2007 Report Share Posted January 8, 2007 http://www.partstore.com/ModelDetail.aspx?...e=0&exact=1Look through this list of parts for your unit, they probably have it. Quote Link to comment Share on other sites More sharing options...
Richard Posted January 8, 2007 Report Share Posted January 8, 2007 I think if you look at the NH900 service manual from the downloads section, the Sony part number you need is: 3-234-449-19. If partstore.com doesn't have it you should be able to quote the part number to Sony Support in the UK. Quote Link to comment Share on other sites More sharing options...
A440 Posted January 8, 2007 Report Share Posted January 8, 2007 Sony will charge outrageous amounts. Go to an optician or eyeglasses store and talk to their repair department. They have lots of tiny screws, one of which is likely to fit your NH900. You can also look at eyeglasses repair kits sold at chemists', etc. Quote Link to comment Share on other sites More sharing options...
raintheory Posted January 8, 2007 Report Share Posted January 8, 2007 I've repaired 2 MZ-N707's (notorious for losing screws) with eyeglass repair kits. Great suggestion A440 Quote Link to comment Share on other sites More sharing options...
bobt Posted January 8, 2007 Report Share Posted January 8, 2007 ditto on the eyglass kit, also try an electronic repair shop, that should get you going. Another alternative buy a junker unit for parts, I have a 707 and NH1 that I can cannibalize,If you can't find anything PM me and I will send you a couple,Bob Quote Link to comment Share on other sites More sharing options...
eveningsong Posted January 17, 2007 Author Report Share Posted January 17, 2007 Thanks you for all your suggestions. I also noticed that even faulty minidiscs are creaping up in price on ebay. I did actually look at my glasses and thought, Nah! they always come out too lol. Quote Link to comment Share on other sites More sharing options...
smekma Posted January 21, 2007 Report Share Posted January 21, 2007 (edited) Hi. Im from Spain so my english is very bad. I'll try xDI have an MzNH900 too and two days ago my MD crash down to the floor and two screws have been lost. Here's two pictures to let you see the exactly screws are.I have looking for that screw in PARTSTORE but I dont know the model. Can you help me please?Oher question. My earphones are broken, MDR-E808, PARTSTORE has one but I think its too expensive, do you know other place to buy them (not ebay please)? or another earphones that works as well like that?THKS Edited January 21, 2007 by smekma Quote Link to comment Share on other sites More sharing options...
Mr_Bass_Man Posted January 21, 2007 Report Share Posted January 21, 2007 I think if you look at the NH900 service manual from the downloads section, the Sony part number you need is: 3-234-449-19. If partstore.com doesn't have it you should be able to quote the part number to Sony Support in the UK.The original poster should be in luck, as that part is indeed listed in Partstore.However another alternative is to cannibalise another unit (look on EBay for cheap non-workers)- like another in this thread my son has an N707 which lost a couple of screws, and I obtained replacements for it in this way.It is always worth checking the tightness of your case screws every now and then with an appropriate jewellers' screwdriver, as this does seem to be a fairly common problem, probably due to the flexing of the case during normal day-to-day use.Hope this helps Quote Link to comment Share on other sites More sharing options...
jonny mac Posted January 22, 2007 Report Share Posted January 22, 2007 I eventually went into a Sony Centre last time I was home in the UK & they very helpfully provided me with (& fitted) a spare screw, no charge. However, they weren't able to provide me with any spares for the future.Smekma, I don't know where you are in Spain but there are Sony Centres here, in Madrid at least. You could try them. Below are a couple on online retailers in SPain, both specialising in Sony stuff. Maybe you could contact themto help you out?http://www.tiendasony.com/index.phphttp://www.sonygallery.com/ Quote Link to comment Share on other sites More sharing options...
milomind Posted January 22, 2007 Report Share Posted January 22, 2007 Thanks you for all your suggestions. I also noticed that even faulty minidiscs are creaping up in price on ebay. I did actually look at my glasses and thought, Nah! they always come out too lol.Paint a small dab of Loctite on the screw threads. A very small amount will go a long way with glasses, and MDs. Quote Link to comment Share on other sites More sharing options...
