MZ-RH10 Display
comspec
I have an RH-910, and its biggest problem was not the display fading (which it did) but simply the voltage driving the display falling below spec.
One relatively simple power adjustment and it came right.
I wonder if the RH10 might just happen to be similar? (other LCD units certainly have been). I know the urban myth is that the OEL display fails, but perhaps not.....
Guest Talisin
My RH10 have had no problem with its display. Bright is the same now than when I buyed it second hand 'bout 4 years ago. Only problem with it is not charging batteries and not recognizing battery charge, so till I drive it to technical service (I hope tomorrow) is not very usable.
  • 3 months later...
Talisin: what power adjustment did you make on your 910? I'd be interested to try this on the RH-10. I'm assuming its an adjustment you made in the service mode? Might be worth a shot.
Guest Talisin
Wasn't me who didt hat adjustment. I even don't have arh910 :P. Ask Sfpb about that ;)
  • 4 weeks later...
