MZ RH1 - Lifespan
PogoPogoPogo
Hi all,
I'm no stranger to the world of MD, but I didn't know there was such a loyal following way after MP3 players took over everything.
Now, to pop my forum cherry here (sorry), I would like to discuss the MZ RH1, specifically how long it lasts with frequent use (playback only) before it begins to show signs of problems and/or dying.
When I got mine years ago I was most disappointed with just how frail the build quality is. Because of this, I rarely use it and whenever I do, it's strictly for playback only, indoors, and using the remote.
So, how many of you RH1 owners been able to use it on a fairly regular basis without it failing on you? How many years of use have you managed to get out of it so far?
Thanks in advance!
Pogo
My MZ-M200 (or RH1) has the problem with the forward/ fast forward button not working. I used to use it to record this local band that I know and I ended up dropping it once or twice and luckily I only put a few scratches on it. Now I just use some of my other portables to record the shows and then use the M200 just for uploading to my computer. I want to preserve it for as long as I can because a replacement unit will cost alot.
Yes the forward and rewind switch is wobbly and seems prone to breaking, and I feel like I'd crush the tiny thing every time I press the volume buttons, which is why I only use the remote for it! I'm amazed yours survived after dropping even once.
The RH1 had such potential to be the best Minidisc recorder EVER, but due to what I can only imagine as rushed or lazy design choices, it falls just short of that in my opinion. Bah. Still, I love it, it looks great and sounds superb so will continue to use it sparingly for my most favourite music...it kind of makes me appreciate the listening experience that much more.
I got my first RH1 from a guy who gave it a hard life. Quite impossible to change settings with the switch.
Jim Hoggarth finally repaired everything this summer.;
Replace display block flexible connector (cracked)
Reformed bent hinge pin on upper slot metalwork
Remove label residue from upper slot metalwork
Glue lid lock strike plate back into position
Replace battery compartment (cracked into two pieces)
Strip and clean all control switch contacts
Replace several missing screws
plus my NH900 and acreplacementcremote ;
Labour: £35.00 + Parts: £22.00
