Just found my treasure box of Hi-MD equipment - Updated, even more...
Akytarus
:crazy: Found My Gold Mine from 7-8 Years Ago :crazy:
2x MZ-RH1's
25x (+24) 1st Gen Hi-MD's
18x (+12) 2nd Gen Hi-MD's
2x Original MZ-RH1 Chargers (AC-S508U)
3x Original MZ-RH1 Remotes (RM-MC38EL)
2x Sets of Sony Headphones,
2x Fux Black Leather Cases
2x Sony Branded Soft Draw String Pouches (Grey)
7x Li-ion MZ-RH1 Batteries (LIP-4WM)
1x Optical Cable (Mini jack to Mini jack)
1x Sony CD DiskMan With Optical Output For MiniDisk (D-EJ825) [NOT PICTURED]
1x Fiio E17 24Bit USB/Analog DAC
I wonder whats its all worth....?
--- NEW 7th Nov --- Just found an extra folder (thought it was a folder of CD's...!) with another 24x 1st & 12x 2nd Gen Hi-MD's
:mda: MD's are numbered and there was a paper inside saying what was on each disk - I don't remember doing this.....! :mda:
Seriously. Those blanks alone are worth a fortune!
At my current count I have 79x Hi-Md's (unless I find more....)
So at current eBay rates of 25$-40$ for one disk that would be $1975-$3160 just for the blank media.....! Errrrrrk :heat:
I never knew my Hi-MD equipment and media would become an investment....! :imsohappy:
I've been using one of my MZ-RH1 to listen to lots of awesome 80's stuff I recorded from my parents groovy record (LP) collection. Recording was done in PCM format (as is most of my collection of Hi-MD's. This explains why I have so many of them).
C'est juste impressionnant!
Je ne crois pas avoir vu autant de HI-MD en visuel!!
Pour l'estimation haute (basé sur les prix eBay) j'irais plus entre 2300€ et 2500€ maximum.
Je compte 15€ par Hi-MD (1200€), 800€ pour les RH1, 150€ pour les LIP-4WM (occasion), 100€ pour le Fiio E17 (129€ neuf), 20-30€ pour le D-EJ825.
Après il est possible d'avoir du moins cher. J'ai acheté mon RH1 complet en boite 100€ et je viens de trouver des Hi-MD à 8€ pce (7 en tout)!!
Les prix ebay, ne sont pas une référence à suivre.
Suffit d'être patient et de trouver "La Bonne Occase"!
  • 1 month later...
Damn, I wish I would've collected the "1GB's" like I did "80min's" back when they was dirt cheap. Didn't go with my gut that time either, and its gonna cost me in the long run. First gut feeling, Blu-ray changers. Should've got more than one, then they stopped making them too. Yes, a lucky one indeed.
  • 4 weeks later...
