Can an entire disc be wiped clean by unit (MZ-M200) alone?
msteeln
I'm currently getting my MD collection into my laptop and want some blank discs again to use as backup at gigs I record but am finding trouble in recording over full discs or merely erasing the content. Isn't there a basic way to wipe the discs clean from the unit itself, minus any hookup to a computer? Is there even useable software now for the 200?
Thanx!
If you go into the menu, select Edit and then All Tr Erase remove all music from the disc (or more accurately modify the TOC so the disc is once again treated as a blank disc).  Otherwise you can also format the disc from the unit which will remove all audio and other data from the disc.
