adam30 Posted February 16, 2015 Report Share Posted February 16, 2015 As i need a replacement? Gumstick Rechargeable Battery for Sony MZ-N1 MZ-R909 ebay number: 400701246373 Many thanks Adam Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted February 16, 2015 Report Share Posted February 16, 2015 From mininidisc.org browser, NH1 battery Your battery replace Sony NH-14WM, NH-10WM, NH-10WM B for Sony minidisc as said in the web page details. So if somebody can tell us want is the difference between Nh-10WM B and A. Thick size maybe ? 1 Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 16, 2015 Report Share Posted February 16, 2015 I think the N10 battery is same or similar. LIP-3 and LIP-4WM are convertible but not interchangeable. (One has a cable the other doesn't) But the one you have found is the NiMH gumstick used in many other models. No it is absolutely not suitable. Sorry. The battery is about $50 on Yahoo Japan. I'm considering getting one myself if I can not revive mine. Try leaving the unit plus battery plugged in to cradle for 24 hours. You may be surprised. Quote Link to comment Share on other sites More sharing options...
adam30 Posted February 17, 2015 Author Report Share Posted February 17, 2015 ok thank you. ill check yahoo japan as well thanks. Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted February 17, 2015 Report Share Posted February 17, 2015 Somebody know that one ? HQRP Portable CD / MD / MP3 Battery for Uniross RB103244, RB103246 Replacement plus Coaster http://www.amazon.com/HQRP-Portable-RB103244-RB103246-Replacement/dp/B0047ZW4BM 1 Quote Link to comment Share on other sites More sharing options...
Sargaso Posted February 17, 2015 Report Share Posted February 17, 2015 I tried the HQRP gumstick batteries and I never had any luck with them. They all had high self discharge characteristics and developed high internal resistance pretty quickly. The only NH-14WM replacement I've used that wasn't high self discharge is the Sofirn 3000mah battery from China. Don't let the name fool you , it's no where near 3000mah. Its like 1200mah but will hold a charge. The Sofirn battery is all white in color and its still going after a year now. It's not as good as the original Sony pr Sharp gumsticks were but way better than any HQRP I've ever tried. 1 Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 17, 2015 Report Share Posted February 17, 2015 OP, please note this is another NiMH battery, and NOT what you want. Yes, I saw them at the Walgreen-owned EverState Battery company which has recently disappeared from our neighbourhood (another example like Target of US businesses not succeeding here in Canada, for whatever reason). I think they might be made by-or-for Walmart/Walgreen. Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 18, 2015 Report Share Posted February 18, 2015 On 2/17/2015 at 4:42 PM, Sargaso said: I tried the HQRP gumstick batteries and I never had any luck with them. They all had high self discharge characteristics and developed high internal resistance pretty quickly. The only NH-14WM replacement I've used that wasn't high self discharge is the Sofirn 3000mah battery from China. Don't let the name fool you , it's no where near 3000mah. Its like 1200mah but will hold a charge. The Sofirn battery is all white in color and its still going after a year now. It's not as good as the original Sony pr Sharp gumsticks were but way better than any HQRP I've ever tried. I have yet to find a NiMH gumstick battery (as in MD) which is not revived by the computerised battery chargers typified by BC700 as here: http://www.amazon.com/gp/product/B000RSOV50 Kind regards Quote Link to comment Share on other sites More sharing options...
Sargaso Posted February 18, 2015 Report Share Posted February 18, 2015 Smart chargers can help with recovering some capacity (to a certain point) of the battery by repeated charge/discharge but can't do anything about decreasing internal resistance. 1 Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 19, 2015 Report Share Posted February 19, 2015 That often seems to happen tho. The symptom is battery gets very hot exactly once and then after that is recovered. Something to do with NiMH crystals. Quote Link to comment Share on other sites More sharing options...
Sargaso Posted February 19, 2015 Report Share Posted February 19, 2015 I have tried the "burn out" methods, including both the short duration 12v application to the battery and using a dumb charger like sony mz-r90/91 to charge. The battery does indeed get warm in the r91 during charging but didn't really fix anything. I'm sure some internal resistance can be reduced by these methods in some batteries depending on the conditions that caused the high resistance but it's just never worked in any of the batteries that came with any of the MD's I've purchased and of course none of the HQRP batteries. Anyway I'm pleased with the performance of the Sofirn NiMH's I'm currently using. Actually this post confused me. I didn't realize the OP was needing a replacement for the LIP-4WM. Should have looked at the topic closer. I wish I could report a good source for the LIP-4WM but they just don't seem to be out there. I keep thinking that some Chinese company will come out with a replacement but have not seen any yet, maybe someday. Quote Link to comment Share on other sites More sharing options...
