Ultima Posted March 12, 2003 Report Share Posted March 12, 2003 Hi all, My N10 (Japanese import) has firmware version 1.300 Can it be upgraded in the (near) future, or is it 'as is' Does anybode know the difference between the versions ??? Cheers, Aad Quote Link to comment Share on other sites More sharing options...
Lustral Posted March 12, 2003 Report Share Posted March 12, 2003 how u find out the version Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 12, 2003 Report Share Posted March 12, 2003 how u find out the version http://forums.minidisc.org/viewtopic.php?t...er=asc&start=90 Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 12, 2003 Report Share Posted March 12, 2003 Hi all, My N10 (Japanese import) has firmware version 1.300 Can it be upgraded in the (near) future, or is it 'as is' Does anybode know the difference between the versions ??? Cheers, Aadit's not upgradeable. Quote Link to comment Share on other sites More sharing options...
Ultima Posted March 12, 2003 Author Report Share Posted March 12, 2003 Getting into the Service Mode of an N10 is not the same as for the 707. The correct sequense is: 1 Put the main unit on hold. 2 Keep the 'group'-button pressed while using the joystick do nr.3 3 >> , >> , << , << , >> , << , >> , << , || , || (right,right,left,left,right,left,right,left,pause,pause) Now you are in service mode. To 'hold' the display from toggling around, press the pause button. Leave Service Mode by switching off the unit completely (switch on back side) Cheers, Aad Quote Link to comment Share on other sites More sharing options...
Lustral Posted March 19, 2003 Report Share Posted March 19, 2003 Mines a 1.300 that my dad got from HK , but it came with a RM-MC33EL remote i want the 35EL remote. Plus im still looking for the USB cable for it. Thanks Quote Link to comment Share on other sites More sharing options...
\-=Golden=-// Posted March 23, 2003 Report Share Posted March 23, 2003 my one is 1.100 -=Golden=-// Quote Link to comment Share on other sites More sharing options...
ZenmasteR Posted March 29, 2003 Report Share Posted March 29, 2003 what are the differences between the firmwares? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 30, 2003 Report Share Posted March 30, 2003 i do not think sony will give us the chance to upgrade out firmare Quote Link to comment Share on other sites More sharing options...
baal Posted March 30, 2003 Report Share Posted March 30, 2003 my is 1.20 and who can tell me how to change the setting in service mode and what do the settings mean? Quote Link to comment Share on other sites More sharing options...
Daijoubu Posted March 31, 2003 Report Share Posted March 31, 2003 my is 1.20 and who can tell me how to change the setting in service mode and what do the settings mean?Don't play with the settings...you could destroy the optical block :wink: Quote Link to comment Share on other sites More sharing options...
AlienKarma Posted March 28, 2004 Report Share Posted March 28, 2004 My is 1.600 Quote Link to comment Share on other sites More sharing options...
geed Posted March 31, 2004 Report Share Posted March 31, 2004 My is 1.600.. us model? Quote Link to comment Share on other sites More sharing options...
AlienKarma Posted April 3, 2004 Report Share Posted April 3, 2004 Nop. European Quote Link to comment Share on other sites More sharing options...
MDX-400 Posted April 15, 2004 Report Share Posted April 15, 2004 what are the differences between the firmwares?You are correct. The firmware version is not user-upgradeable and Sony will not release the upgrade firmware and software to the general public. The firmware is, however, upgradeable on most NetMD units. The service manuals point out the procedure for updating the firmware. It is done with special Sony software only available to technicians and is performed over the USB cable. As for the differences, well one person's guess is as good as anothers... Since the firmware updates aren't made publicly available, whatever changes were made in each version is also not available. Furthermore some products, even where the firmware is available publicly they still don't tell you what the differences are! LOL. Quote Link to comment Share on other sites More sharing options...
