LP2 or LP4?
two.tread
you can get twice as many songs on with lp4 but now and again you can hear that it's not top notch audio... i masked some of this with trying some better suited headphones. that were made by sony. you might do 1 minidisc with 10 albums on it in lp4, like i have, stuff i don't listen to as much. and do your favourite 5 albums on one minidisc in lp2... B)
Well, LP4 certainly beats recording in SP Mono ..
I usually put ambient music on LP4 because it sounds better (yeah, I know that sounds ridiculous).
LP2 is definitely the best tradeoff between CD quality and space on an MD. Just make sure whatever you're recording to this mode has a bitrate higher than its encoding. That is unless you want loads of artifacts when transcoding from a 96 kbps mp3 file to LP2's 132 kbps.
(Someone find me the right words for this .. ^_^ )
IMO, LP4 is only good for voice recordings, especially if you use a mono mic and a plug that balances the signal across both channels. Music encoded with LP4 sounds like cacca - yeah, it's nice to have so much music on one disc, but good will that do when you can't stand to listen to it?
Let your ears be your guide, record a few songs yourself, then playback on shuffle, if you can't tell the difference, go with the lower bitrate. Most will agree though that LP4 is not true fidelity, but if you are recording low bitrate MP3's it shouldn't matter.
Let us know what YOU think,
Bob
A few months ago, I would have said definitely LP2, but now I am not so sure. I like the "Let your ears be your guide" response. When I bought a used Sony MDLP head unit for my new car, it came with dozens of mostly LP4 MDs, mostly rock.
While their sound is not as good as LP2 and even more obviously not as good as SP, it's still listenable to me.
This led me to play with LP4 at home, on my MXD-D400, MXD-D40, and JB-940 decks (via my main home systems), as well as my MZ-R500 (using headphones)at work. It sounds all right for the most part everywhere, at least to me.
What I really like is that 5+ hours of uninterrupted play!
...or you could get a HiMD and get 8 hours of HiSP (256kbps) and do not have to choose quantity over quality
...or get the RH1 and put Lame VBR new V4 MP3's on there and you'll have even more music at a good/great quality
still while I do agree with the use what works best for you idea, I personally wouldn't enjoy 5 hours of music if I knew and more importantly I could hear it was inferior quality
LP2 is listenable and great for mobile conditions, LP 4 is not period!!!! I have found even in LP2 with EX90's the detail is incredible but, its flaws are also revealed as well. As said before let your ears be the guide. This is just my opinion that is all it is. I have alot of recordings in LP2 and it is ok. It allows you to travel with a minimum compliment of disc but, I don't really enjoy them. I'm satisfied with LP2 but not happy.
Hi !
LP2 is fine for portable listening, but I suppose it also depends on what you are listening to. I find LP2 (listening to hip-hop) via Audio-Techina earphones to be more than acceptable. And I fit approx. 15 albums on a single 1GB Hi-MD blank.
At home I use 352kbps (via my MZ-NH900 line-out) for non-headphone sessions.
It's all about trade-off between space & quality. (also, the headphone quality is very important).
I choose the recording format according the sound quality of the source.
WHen I use optical cable to record CD quality music, I choose LP2
When I use jack to jack to record music with Line-in, I just choose LP4. MP3 is a little splitting here. In most cases I use LP2 if MP3 files are 128KHZ and above.
