RH10 not charging battery properly
doomlordis
Read through other threads and not found similar issue. When i put in a battery (discharged
) it charges for 1 - 1.5 hours then screen goes off, now i know it should take 3.5hrs roughly , i have tried this with all 3 of my nh14wms and they all behave the same??
If i press stop again it starts charging again for another 1-2 hrs??
Maybe i should buy a external charger!
Edited by doomlordis
The screen only stays on for about an hour. After it goes out (at ~80% capacity), charging continues for another three hours or so.
Re-check your manual. :)
EDIT: Oops, I keep confusing the RH1 with the RH10. There could be multiple causes for this charging behavior. Did you try cycling the batteries? Do they have a known good capacity? Are the contacts on both the cells and the RH10 clean?
Edited by e1ghtyf1ve
Are you charging through the USB or the adapter? Charging with the USB port will only bring the battery up to 75-80% capacity. In order to fully charge the battery you must use the adapter. it's 3V AC in case you don't have one.
where did you get that? just curious. i thought its the same to charge from the computer or from the adapter, with my RH1 i use the adpater for consistency since my computer is always going on and off.
As with doomlordis' question i think it has to do with the peak voltage detection method used in the charging mode. i really don't recommend that you charge your ni-mh batteries again after it has just been charged.
Edited by Sparda
I know that 1 hr isnt enough to fully charge a nh14wm, so charging again is my only option (it works - i am getting about 12 hrs playback)
The charging times for the RH10? The owners manual.
The RH1 however, will fully charge from either the adapter, or the computer. Again, from the manual.
  • 10 months later...
It could be a faulty battery - where did you acquire it? The are a few fake gumsticks floating aroud on ebay and the like.
I've bought them in a local Sony dealer here in Madrid, Spain.
EDIT: I've removed the 1GB MD out of the unit and now is charging! I can't understand why ... but it works.
Edited by romateo
I did not mean the contacts of the battery itself. The contacts of the unit may also need cleaning.
And a fake NH-14WM is not an unheard of thing nowadays. If you turn a NH-14WM battery upside down and see a "FOR NH-10WM" in the middle of the text - it is a fake! Charges in a couple of hours, discharges in 3-4 hours. But it will eventually swell inside the unit, and damage it - so be very carefull!
Edited by Avrin
How should I clean the negative (-) contact that is inside the unit?
Thanks again, Avrin.
I think the battery compartment lid is a bit loose. How can I tight-fit it?
Forget about it - it almost never gets dirty. Just clean the positive one.
This may or may not be a serious problem. Is it loose only when opened? Or is it loose even when closed? In the latter case you've got a problem, since the battery door on the RH[9]10 is a very fragile thing, and any attempt to fix or modify it may lead to serious damage, the door may even be broken completely.
Edited by Avrin
