marc-hd Posted November 3, 2007 Report Share Posted November 3, 2007 Hi, any mac users with leopard have tested the Hi-Md transfer for mac?? Does it work with the new OS X Leopard?? Marc Quote Link to comment Share on other sites More sharing options...
bobzilli Posted November 5, 2007 Report Share Posted November 5, 2007 Sorry, I'm holding off on Leopard until they work out the bugs Quote Link to comment Share on other sites More sharing options...
srizvi1 Posted November 5, 2007 Report Share Posted November 5, 2007 I'll be able to tell you soon. I have my new refurbished 15" 2.2ghz MacBook Pro w/ a Leopard drop in disc on the way and it should be arriving tomorrow. Once I get it, I'll be pulling some stuff off of my minidiscs onto it. I'll post my updates to this thread in case you want to subscribe to it or anything. Quote Link to comment Share on other sites More sharing options...
marc-hd Posted November 5, 2007 Author Report Share Posted November 5, 2007 Thanks! i would like to upgrade my macbook soon. I'll be waiting your reply. Quote Link to comment Share on other sites More sharing options...
tenacious-c Posted November 9, 2007 Report Share Posted November 9, 2007 Thanks! i would like to upgrade my macbook soon. I'll be waiting your reply.I can check it out tonight-I have been running Leopard for about 1 1/2 weeks now, but didn't think to check on the MD software. Quote Link to comment Share on other sites More sharing options...
srizvi1 Posted November 9, 2007 Report Share Posted November 9, 2007 (edited) Where's the best place to download the software? I got my Mac up and running. I have done some recordings with my Minidisc that I want to import too. I don't feel like going downstairs and finding my RH1 box though with all the software Edited November 9, 2007 by srizvi1 Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 9, 2007 Report Share Posted November 9, 2007 The downloads section here in the forums has the most recent version of the software.I wouldn't recommend installing the software that came with the RH1, as it lacks some fuctionality present in the newer version. Quote Link to comment Share on other sites More sharing options...
Richard Posted November 9, 2007 Report Share Posted November 9, 2007 * Moved to Software Discussion section Quote Link to comment Share on other sites More sharing options...
srizvi1 Posted November 9, 2007 Report Share Posted November 9, 2007 ok, downloaded.. I'll install and work with probably sometime over the next few days. While we're on the subject of software, anything else good for Hi-MD users and Macs? Quote Link to comment Share on other sites More sharing options...
geoffb Posted December 9, 2007 Report Share Posted December 9, 2007 Hi, any mac users with leopard have tested the Hi-Md transfer for mac?? Does it work with the new OS X Leopard?? Marcmy experience so far is that it is not compatible - I have upgraded my G5 to Leopard and tried to use MD-Transfer and no files showing. The disk will mount on leopard but seems that Leopard does not gel so far with MD-Transfer. Hopefully there will be a fix for this soon. I wont put Leopard on my g4 laptop until this is ironed out, a shame as leopard is great (although a few people have had a few probs I know looking a the Apple forum) Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 9, 2007 Report Share Posted December 9, 2007 Leopard , isnt going to run MD Transfer 2.0 , Sony stopped developement on it because they stopped the Portable MD line , their recording is going Flash based . I am also on Mac , and will not upgrade to Leopard , Tiger is fine , I dont need 3D desktop , a flash and fluff , just a machine that works . Quote Link to comment Share on other sites More sharing options...
gblasius Posted December 15, 2007 Report Share Posted December 15, 2007 Sorry, completely confused by this thread! I have a MZ-RH1 and am using Mac OS 10.4.11; I downloaded Hi-MD Music Transfer Version 2.0.00.06273 from the Sony website and...nothing. Downloading is not a problem on my PC running Sonic Stage, so I know its not the hardware. I can't find the 'software downloads' section of this forum (no links here)...any help??? Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 15, 2007 Report Share Posted December 15, 2007 (edited) Sorry, completely confused by this thread! I have a MZ-RH1 and am using Mac OS 10.4.11; I downloaded Hi-MD Music Transfer Version 2.0.00.06273 from the Sony website and...nothing. Downloading is not a problem on my PC running Sonic Stage, so I know its not the hardware. I can't find the 'software downloads' section of this forum (no links here)...any help???What exactly is your problem??Here klik this , make SURE that you READ the directions , and learn how to use the software , I will help if I can , http://support.sony-europe.com/DNA/Softwar...fer/MT.asp?l=enWhen you connect the RH1 look on your desktop for an Icon that is Blue , and says HiMd Monitor or transfer one of the two , double klik IT , and not the drive icon when MD Transfer window opens , it might take a sec , but then your files will show up .The ONLY files that you can see will be in HiMD mode , you CANNOT transfer Regular MD SP or anything not HiMD , it just wont show up . Edited December 15, 2007 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
gblasius Posted December 19, 2007 Report Share Posted December 19, 2007 What exactly is your problem??Here klik this , make SURE that you READ the directions , and learn how to use the software , I will help if I can , http://support.sony-europe.com/DNA/Softwar...fer/MT.asp?l=enWhen you connect the RH1 look on your desktop for an Icon that is Blue , and says HiMd Monitor or transfer one of the two , double klik IT , and not the drive icon when MD Transfer window opens , it might take a sec , but then your files will show up .The ONLY files that you can see will be in HiMD mode , you CANNOT transfer Regular MD SP or anything not HiMD , it just wont show up .I've READ the directions, and I've INSTALLED the software, called 'Hi-MD Music Transfer.' The problem is that it just doesn't 'see' the Hi-MD when it is connected via a USB cable. To ensure the hardware, etc was OK, I installed 'Sonic Stage' on a Wintel laptop...no problems, saw the external drive ok, downloaded the recordings, no problem. Via Apple (Mac OS 10.4.11), using Hi-MD Music Transfer, nothing. Apple Finder doesn't report mounting any device either. Your help appreciated. Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 19, 2007 Report Share Posted December 19, 2007 What model mac again , and which port are you connected to ? Quote Link to comment Share on other sites More sharing options...
tbbeqa Posted December 23, 2007 Report Share Posted December 23, 2007 Hi, any mac users with leopard have tested the Hi-Md transfer for mac?? Does it work with the new OS X Leopard?? MarcI just tried to use it on a MacBook Pro with Leopard and it could not detect the MD device.I went back to another computer with OSX 10.3 to do the job and it worked. I doubt if Sony will respond soon.Tom Barker Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 23, 2007 Report Share Posted December 23, 2007 I wonder if he is on a PPC machine , I think MD Vers 2 might be for Intel mainly . Quote Link to comment Share on other sites More sharing options...
Sixx Posted December 24, 2007 Report Share Posted December 24, 2007 I installed Hi-MD Transfer v2 on MacBook Pro (with Leopard, 10.5.1), connected mz-rh1, started the Hi-MD Transfer app and everything works.I don't use the HI-MD monitor, because it's PPC only application and runs as daemon in background so it's better to start Hi-MD Transfer manually.Anyway, importing/exporting work with no problems here. Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 24, 2007 Report Share Posted December 24, 2007 I installed Hi-MD Transfer v2 on MacBook Pro (with Leopard, 10.5.1), connected mz-rh1, started the Hi-MD Transfer app and everything works.I don't use the HI-MD monitor, because it's PPC only application and runs as daemon in background so it's better to start Hi-MD Transfer manually.Anyway, importing/exporting work with no problems here.wow , ok cool , so how did you seperate the MD monitor from the Transfer prog , It loads both when installing . or did you manually remove the Monitor? Quote Link to comment Share on other sites More sharing options...
tbbeqa Posted December 25, 2007 Report Share Posted December 25, 2007 I just tried to use it on a MacBook Pro with Leopard and it could not detect the MD device.I went back to another computer with OSX 10.3 to do the job and it worked. I doubt if Sony will respond soon.Tom BarkerI had done a "previous computer transfer" to my new Intel powerbook. Later I reinstalled the latest 2.0 version and I'll bet the drivers were installed.NOW IT WORKS! Quote Link to comment Share on other sites More sharing options...
tbbeqa Posted December 25, 2007 Report Share Posted December 25, 2007 Hi, any mac users with leopard have tested the Hi-Md transfer for mac?? Does it work with the new OS X Leopard?? MarcI need to revise my first reply. When I went to my new MacBook Pro, I simply transfered all my programs via the Macintosh system using a firewire cable. This did not install the driver for the MD device I suppose, and the MD device was not detected when I launched the Hi-MD music transfer program.I reinstalled the Hi-MD Music Transfer program and it works.Bottom line there is no need for any upgrades to use the latest version of the Hi-MD music transfer program to operate on Leopard. Quote Link to comment Share on other sites More sharing options...
Sixx Posted December 25, 2007 Report Share Posted December 25, 2007 wow , ok cool , so how did you seperate the MD monitor from the Transfer prog , It loads both when installing . or did you manually remove the Monitor?You don't need to separate or remove anything. Leave it in you Applications folder, just foloow these steps:1. Run the installer and install both: Monitor and Transfer apps.2. Then go to System Preferences/Accounts/Login Items and delete Hi-MDmonitor from the list.3. Open Activity monitor, find and quit the process, or restart computerThat's it...Next time you connect your Hi-MD unit to your computer you have to start Hi-MD Transfer manually, everything else works great. Quote Link to comment Share on other sites More sharing options...
Strungup Posted December 25, 2007 Report Share Posted December 25, 2007 You don't need to separate or remove anything. Leave it in you Applications folder, just foloow these steps:1. Run the installer and install both: Monitor and Transfer apps.2. Then go to System Preferences/Accounts/Login Items and delete Hi-MDmonitor from the list.3. Open Activity monitor, find and quit the process, or restart computerThat's it...Next time you connect your Hi-MD unit to your computer you have to start Hi-MD Transfer manually, everything else works great.AHHHHH thanks for the info , this is probably the main thing that was keeping me from upgrading to Leopard , I still think I want to wait for a few more updates on Leopard before I jump on board , Tiger has been running fine . Quote Link to comment Share on other sites More sharing options...
Sixx Posted December 26, 2007 Report Share Posted December 26, 2007 AHHHHH thanks for the info , this is probably the main thing that was keeping me from upgrading to Leopard , I still think I want to wait for a few more updates on Leopard before I jump on board , Tiger has been running fine .No problem... Leopard runs fine. 10.5.1 is pretty stable and Hi-MD software works on it as well...I doubt there will be an update for Hi-MD Transfer app, because I have heard Sony abandoned its development. We'll see... Quote Link to comment Share on other sites More sharing options...
elishasessions Posted April 1, 2008 Report Share Posted April 1, 2008 Running a Powerbook G4 with Leopard, and it works, albeit strangely.When I downloaded a fresh 2.0 version of the app and installed on my system, what I got was a folder, instead of an app.I opened the folder, opened "Contents", opened "Mac OS", then launched "Hi-MD Music Transfer", which in turned launched the Terminal as well as the app itself. The Terminal sat there and logged everything the app was doing.For some reason, Leopard isn't seeing it as an application package but as a folder.It works, though! Whew! Quote Link to comment Share on other sites More sharing options...
reefbeef Posted April 19, 2008 Report Share Posted April 19, 2008 You don't need to separate or remove anything. Leave it in you Applications folder, just foloow these steps:1. Run the installer and install both: Monitor and Transfer apps.2. Then go to System Preferences/Accounts/Login Items and delete Hi-MDmonitor from the list.3. Open Activity monitor, find and quit the process, or restart computerThat's it...Next time you connect your Hi-MD unit to your computer you have to start Hi-MD Transfer manually, everything else works great.Admin:This is extremely useful information. There is a lot of misinformation out there on this important topic. Can you make it more visible, please? Even minidisco has it wrong on their M200 page. It states that it is not compatible with leopard. Thanks a ton, Sixx, for this post... Quote Link to comment Share on other sites More sharing options...
Mitmensch Posted May 9, 2008 Report Share Posted May 9, 2008 (edited) Running a Powerbook G4 with Leopard, and it works, albeit strangely....hi, everyone. I have a problem with the program v.2.0 running on the C2D 2.4Ghz Macbook with OSX10.5.2before viewing this thread, my macbook can detect my RH1, but i can do nothing with it except using it as an external device. And with the Hi-MD transfer program installed, the program can show the recording data in the program window, but still I can do nothing with it.after viewing the thread, and tried the way mentioned, I cannot do anything except viewing the titles of the recording data only with the program on my Macbook.I have read the notes of the programAnd I wonder if there is a solution to the program running in the OSX10.5.2.please tell me and thanks a lot !!! Edited May 9, 2008 by Mitmensch Quote Link to comment Share on other sites More sharing options...
srizvi1 Posted May 10, 2008 Report Share Posted May 10, 2008 I keep delaying installing the mac software for the MZ-RH1 on Leopard so I can pull my recordings off. I just downloaded the:HiMDMusicTransfer20.dmgVersion : 2.0Last Modified :07/15/2006Size : 1.22 MBfrom:http://esupport.sony.com/US/perl/swu-downl...36&os_id=24I'm going to follow sixx's advice and get rid of the Monitor program since it can't be used by Intel machines. Quote Link to comment Share on other sites More sharing options...
Mitmensch Posted May 11, 2008 Report Share Posted May 11, 2008 from:http://esupport.sony.com/US/perl/swu-downl...36&os_id=24I'm going to follow sixx's advice and get rid of the Monitor program since it can't be used by Intel machines.thx dude, i think why it didn't work out after following sixx's advice was all because my previous program downloading sourcehttp://www.sony-asia.com/support/download/...site=hp_en_AP_iand after trying the program downloading link you provide and following the Sixx's advice...the Program function bloody well without any problem on My OSX10.5.2 intel-based 2.4Ghz MacBookthx Sixx and srizvi1 for the help~ Quote Link to comment Share on other sites More sharing options...
johnwesleybarker Posted July 2, 2008 Report Share Posted July 2, 2008 Hi,I've recently upgraded to Leopard.As I write, it's version is 10.5.4 When I ran Hi-MD Transfer for my MZ-RH1, which I still had in my Applications folder from Tiger, it didn't work. So I followed the advice here and went to http://support.sony-europe.com/dna/downloa...x?l=en&f=MT and followed the installation instructions there and restarted my MacBook Pro (2.4 GHz Intel Core 2 Duo 4GB). Hi-MD Transfer now works perfectly well with Leopard 10.5.4 and I am SO pleased! Quote Link to comment Share on other sites More sharing options...
srizvi1 Posted July 3, 2008 Report Share Posted July 3, 2008 I keep delaying installing the mac software for the MZ-RH1 on Leopard so I can pull my recordings off. I just downloaded the:HiMDMusicTransfer20.dmgVersion : 2.0Last Modified :07/15/2006Size : 1.22 MBfrom:http://esupport.sony.com/US/perl/swu-downl...36&os_id=24I'm going to follow sixx's advice and get rid of the Monitor program since it can't be used by Intel machines.I'm able to use Hi-MD Music Transfer just fine on my 15" MacBook Pro running Leopard. I also believe I got rid fo the Monitor program ok as I Don't see it in my activity monitor. However, I do see mdworker which is 6.29 MB real memory / 608.92 MB Virtual memory. Is this a minidisc related program? Quote Link to comment Share on other sites More sharing options...
raintheory Posted July 3, 2008 Report Share Posted July 3, 2008 (edited) I'm pretty sure "mdworker" is related to spotlight and not anything MiniDisc related. It's footprint should decrease, and/or it should disappear from the activity monitor after it's done it's indexing stuff I'd guess. Edited July 3, 2008 by raintheory Quote Link to comment Share on other sites More sharing options...
Sixx Posted July 7, 2008 Report Share Posted July 7, 2008 I'm pretty sure "mdworker" is related to spotlight and not anything MiniDisc related. It's footprint should decrease, and/or it should disappear from the activity monitor after it's done it's indexing stuff I'd guess.right, it has nothing to do with MD... Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted August 15, 2008 Report Share Posted August 15, 2008 *topic pinned. Many thanks Sixx. Quote Link to comment Share on other sites More sharing options...
greaterbrown Posted September 10, 2008 Report Share Posted September 10, 2008 No luck here. I've got a G5 power PC at home and a G4 power PC at work. No luck with either of them. And yes, I followed sixx's directions diligently. Tried both ver. 1 and 2 of the software. thoughts? Quote Link to comment Share on other sites More sharing options...
baturjan Posted September 11, 2008 Report Share Posted September 11, 2008 No luck here. I've got a G5 power PC at home and a G4 power PC at work. No luck with either of them. And yes, I followed sixx's directions diligently. Tried both ver. 1 and 2 of the software. thoughts?I don't recall every trying it on a PowerPC. That may be the issue. Anyone else using it on a PowerPC? Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 11, 2008 Report Share Posted September 11, 2008 I don't recall every trying it on a PowerPC. That may be the issue. Anyone else using it on a PowerPC?I have an iBook G4 PPC with OSX 10.3.9 on it and MD transfer 2.0 works fine Quote Link to comment Share on other sites More sharing options...
greaterbrown Posted September 11, 2008 Report Share Posted September 11, 2008 I have an iBook G4 PPC with OSX 10.3.9 on it and MD transfer 2.0 works fineBoth of my PPC's are running Leopard 10.5.3Anyone have success with Music Transfer v.1 or 2 on a PPC running 10.5?...cause I got nuthin. Quote Link to comment Share on other sites More sharing options...
Strungup Posted September 11, 2008 Report Share Posted September 11, 2008 Both of my PPC's are running Leopard 10.5.3Anyone have success with Music Transfer v.1 or 2 on a PPC running 10.5?...cause I got nuthin. Tiger on PPC I can see , but running Leopard on a PPC is pushing it to far , like Overclocking A Dell Laptop made for WIN98 and putting XP SP3 on it with only 128 MB memory ,and a P2 processor .......... It will run , but there are a lot of things it just wont do . The Hardware and the Software have to agree . Secondly Sony hasn't updated MD Transfer to work with Leopard , it was made for OSX in it's earlier forms . Leopard is a whole new rewrite of OSX , Completely new architecture , and the programming language has changed a bit . So I cant really see MD Transfer running freely on Leopard , that is why I am still on Tiger . Leopard is pretty , .......... BUT ......... Quote Link to comment Share on other sites More sharing options...
greaterbrown Posted September 13, 2008 Report Share Posted September 13, 2008 Tiger on PPC I can see , but running Leopard on a PPC is pushing it to far , like Overclocking A Dell Laptop made for WIN98 and putting XP SP3 on it with only 128 MB memory ,and a P2 processor .......... It will run , but there are a lot of things it just wont do . The Hardware and the Software have to agree . Secondly Sony hasn't updated MD Transfer to work with Leopard , it was made for OSX in it's earlier forms . Leopard is a whole new rewrite of OSX , Completely new architecture , and the programming language has changed a bit . So I cant really see MD Transfer running freely on Leopard , that is why I am still on Tiger . Leopard is pretty , .......... BUT .........Not quite right. I think Leopard incorporates more native code than Tiger does so it's actually LESS processor intensive than earlier versions. The OS is larger, but takes less to run it which is pretty cool. On my duel G5, I see no speed diff. between 10.5 and the earlier versions....except that I've got no music transfer. Quote Link to comment Share on other sites More sharing options...
