Distorted Vision Posted February 9, 2024 Report Share Posted February 9, 2024 I am recording from Qobuz to my MZ-N920. The Qobuz software is running on my PC and is connected to my Audiolab M-DAC+ by USB cable. The MZ-N920 is connected to the optical output of the M-DAC+. The recordings sound great but automatic track split isn't working. It's recording all the tracks as a single track. I've tried using both the WASAPI driver and the ASIO driver for the M-DAC+ in Qobuz. Anyone got any suggestions please? Quote Link to comment Share on other sites More sharing options...
BearBoy Posted February 9, 2024 Report Share Posted February 9, 2024 It's been a while since I've recorded from my PC in real time but last time I tried streaming from both Spotify and iTunes resulted in the track splits being in the correct place, as long as there was a gap between songs. If two songs flowed into one another then they came over to the MD as a single track and needed to be split manually. Mine were recorded via a Focusrite Scarlet 8i6 into an MDS-JB980 using digital coaxial. Not sure about portables, but the decks have settings to enable automatic track marking when not recording from CDs. This is from the instructions for the MDS-JB980: I'll see if I can find anything similar for the MZ-N920. Quote Link to comment Share on other sites More sharing options...
BearBoy Posted February 9, 2024 Report Share Posted February 9, 2024 Doesn't look like the Z-N920 has quite the same functionality as the decks Can't see any mention in the manual of being able to adjust the trigger level for automatic track marking. Just found this reference to recording from non-CD sources in my translated copy of the manual: Page 92 goes on to say: Found this is the manual for the MZ-N910 (which is very similar to the 920): Have you got SYNC REC turned on? Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 10, 2024 Report Share Posted February 10, 2024 I don't think SYNC REC works properly for most digital sources. In fact I think it may only work when the S/PDIF signal actually disappears. I'm sure you're aware that the red book specification on CDs always has a 2-second lead in allowing sychronization. Unfortunately for you a lot of CD players will completely hide that 2 seconds. a lot of folks have struggled with gapless recording for the opposite reason to you. Originally also CD tracks used to have the equivalent of track marks in them, but nobody uses that any more (in I would guess 20+ years). (help me you nerds of red book!) The exception to this rule is the PCLK-MN10 (or MN20). It turns off the digital signal so that you see a drop. YMMV. Even when you can get it to work (with the level setting which isn't there on portables), there is a problem where it drops out and makes a track mark you're not expecting. For example in a piece of classical music where everyone is silent for a bar and they come in together double-forte. Quote Link to comment Share on other sites More sharing options...
