Guest tony wong Posted March 2, 2005 Report Share Posted March 2, 2005 for me, very personal opinion :40ELK looks very stupid, and it is too big.....but it seems there some searching abilities missing if u have the smaller remote control(3xELK)what's ur opinion and choice?as far as I know : not until the moment u see the stock finally in ur local store, the choice of remote control and manual is not presetyes, that will mean at such a early times, for the 2nd gen, u still can fight for what u want for the remote control Quote Link to comment Share on other sites More sharing options...
daremo Posted March 2, 2005 Report Share Posted March 2, 2005 (edited) Once you go ELK, you never go back! (the bigger one that is...) Edited March 2, 2005 by daremo Quote Link to comment Share on other sites More sharing options...
yamagatacamille Posted March 2, 2005 Report Share Posted March 2, 2005 neither; they should've been stocked w/ the new RM-MC55ELK -- stupid sony Quote Link to comment Share on other sites More sharing options...
Guest tony wong Posted March 2, 2005 Report Share Posted March 2, 2005 yamagatacamille said: neither; they should've been stocked w/ the new RM-MC55ELK -- stupid sony←takes a lookanyway, the choice of remote control is not 100% fixed for any model Quote Link to comment Share on other sites More sharing options...
MZ-NH1 Posted March 2, 2005 Report Share Posted March 2, 2005 I have the bigger remote, and really like the 3 line text thing. Yes it is a bit bulky... but it is much better than only 1 line of display and waiting 30-40secs for all the text to be scrawled across the screen Quote Link to comment Share on other sites More sharing options...
yamagatacamille Posted March 2, 2005 Report Share Posted March 2, 2005 tony wong said: takes a lookanyway, the choice of remote control is not 100% fixed for any model←it's used for the D-NE20, and D-NE920 atrac3+ PCDP Quote Link to comment Share on other sites More sharing options...
Guest tony wong Posted March 2, 2005 Report Share Posted March 2, 2005 yamagatacamille said: it's used for the D-NE20, and D-NE920 atrac3+ PCDP←seems I forgot to post the linkhttp://www.ecat.sony.co.jp/audio/walkman/p...0349&KM=MZ-RH10 Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted March 3, 2005 Report Share Posted March 3, 2005 I would prefer to couple the RM-MC55ELK with the RH10 instead since I already have the 40ELK.Note to self: Get a NE20! Quote Link to comment Share on other sites More sharing options...
roguefan99 Posted March 3, 2005 Report Share Posted March 3, 2005 Between the two of them in style I prefer the 40 style with three lines, easier to scroll eaiser to read, and see all the details at once that I want. I dont find it that much bigger, actually it feels a bit shorter (have to check this, dont have the 33 with me), so I dont knock it around as much Quote Link to comment Share on other sites More sharing options...
The_Stamp Posted March 3, 2005 Report Share Posted March 3, 2005 lol i am honestly fine with my 11el! i just LOVE the bomb trigger thing! (the stop button)has added effect when carrying big black bag. Quote Link to comment Share on other sites More sharing options...
Jyler Posted March 4, 2005 Report Share Posted March 4, 2005 On the same topic, is a 40ELK worth the £50/60 odd quid it costs to buy it?I was looking at getting one for my NH700, but I'm unsure about the price.(I can afford it, but it seems a lot for a remote...) Quote Link to comment Share on other sites More sharing options...
Guest tony wong Posted March 4, 2005 Report Share Posted March 4, 2005 Jyler said: On the same topic, is a 40ELK worth the £50/60 odd quid it costs to buy it?I was looking at getting one for my NH700, but I'm unsure about the price.(I can afford it, but it seems a lot for a remote...)←u should ask somebody else to try this first(maybe someone in this forum)although it seems that 40ELK will work for NH700, but no one can guaranteed until really try it in reality Quote Link to comment Share on other sites More sharing options...
Michael1980 Posted March 4, 2005 Report Share Posted March 4, 2005 The 3 line remote is pretty nifty. Quote Link to comment Share on other sites More sharing options...
yamagatacamille Posted March 5, 2005 Report Share Posted March 5, 2005 tony wong said: u should ask somebody else to try this first(maybe someone in this forum)although it seems that 40ELK will work for NH700, but no one can guaranteed until really try it in reality←maybe not reality, but the World tourist model of the NH700 is supplied with the 40ELK -- and looking at stock photos from sony's eCatalog site, it appears to work properly w/ the NH700Jyler, audiocubes sells the 40ELK remote for about £42-ish -- but that's before shipping, and well, you're back at square one there. Quote Link to comment Share on other sites More sharing options...
Christopher Posted March 6, 2005 Report Share Posted March 6, 2005 The poll results are clearly indicitive that the 40ELK would be a superior accessory. They didn't include it because second generation needed to be cost effective to raise attractiveness, and on unit functionality is much better this time around. Quote Link to comment Share on other sites More sharing options...
Guest tony wong Posted March 7, 2005 Report Share Posted March 7, 2005 kurisu said: The poll results are clearly indicitive that the 40ELK would be a superior accessory. They didn't include it because second generation needed to be cost effective to raise attractiveness, and on unit functionality is much better this time around.←no, no one can be sure at this moment on which model of remote control will be equipped with 2nd gen Hi-MD unitsbelieve, remote + handphone/earphone and manual is the latest thing into consideration for pushing out a Sony modelthese 3 things can change at any moment Quote Link to comment Share on other sites More sharing options...
arb226 Posted March 9, 2005 Report Share Posted March 9, 2005 I have the Sony RM-MC33EL attatched to my Sony MZ-NH600D and it works BEAUTIFULLY! Every function I could want on a remote so I don't have to use the player. I can even turn the unit on and off with the remote. If I get another Hi-MD player/recorder (keeping a close eye on the supposed MP3 native playback enabled units), the RM-MC33EL may just have to migrate to the new unit Quote Link to comment Share on other sites More sharing options...
Fat Tires Posted March 10, 2005 Report Share Posted March 10, 2005 arb226, the new units will come with new remotes. Quote Link to comment Share on other sites More sharing options...
