danielbb90 Posted April 12, 2006 Report Share Posted April 12, 2006 Hi When I transfer Albums from SonicStage I get Album Art on My Hi-MD...It looks pritty but what use has it got? Preview Quote Link to comment Share on other sites More sharing options...
jaylen Posted April 12, 2006 Report Share Posted April 12, 2006 If you had a DH10P, I'm sure the album art would look "pritty" on its color screen. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 12, 2006 Author Report Share Posted April 12, 2006 Oh, Similar to the iPod? Quote Link to comment Share on other sites More sharing options...
jaylen Posted April 12, 2006 Report Share Posted April 12, 2006 Oh, Similar to the iPod?Yes. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 12, 2006 Author Report Share Posted April 12, 2006 Thanks, Quote Link to comment Share on other sites More sharing options...
atrain Posted April 12, 2006 Report Share Posted April 12, 2006 looks awesome on my vaio pocket Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 13, 2006 Author Report Share Posted April 13, 2006 looks awesome on my vaio pocketI just did a bit of quick reaserch on what that was...Woah, Why haven't I come across one of them before? I bet it would look awesome! Quote Link to comment Share on other sites More sharing options...
MDX-400 Posted April 13, 2006 Report Share Posted April 13, 2006 If you don't plan to ever get a unit like the DH10P or other ATRAC device which can utilise the pictures I would advise against using them in SS. It isn't a big deal, they are only a few K I guess but they do take up extra space when you transfer them to the device. For example if I put an album art on an album in SS and transfer to my HD3 it will transfer the album art as well. Only the HD3 will never show the album art since it isn't capable but it does transfer anyway 'cause SS is silly like that. So it's still wasting some HDD space so I avoid using it. Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 13, 2006 Author Report Share Posted April 13, 2006 I want to get one... I just can't afford it at this moment! Well I'll keep them there, Well I like them! Quote Link to comment Share on other sites More sharing options...
sebastianbf Posted April 13, 2006 Report Share Posted April 13, 2006 Hi When I transfer Albums from SonicStage I get Album Art on My Hi-MD...It looks pritty but what use has it got? PreviewWhat did yuo do to make SS put the album art on folders automatically? I have to put it manually before transfering the music to the dh10p. Quote Link to comment Share on other sites More sharing options...
Richard Posted April 13, 2006 Report Share Posted April 13, 2006 What did yuo do to make SS put the album art on folders automatically? I have to put it manually before transfering the music to the dh10p. I don't think it is completely automatic - sometimes when cddb gets the album info it also retrieves the album art which in SS 3.4 it displays in a pop-up. You can then drag this into the title bar on to the square in the Import A CD window and it will be assigned to the album in My Library.In my experience (at least for the albums in my collection) this happens about 1 time in 10. Quote Link to comment Share on other sites More sharing options...
Asia Posted April 13, 2006 Report Share Posted April 13, 2006 it's also displayed on PSP Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 13, 2006 Author Report Share Posted April 13, 2006 I don't think it is completely automatic - sometimes when cddb gets the album info it also retrieves the album art which in SS 3.4 it displays in a pop-up. You can then drag this into the title bar on to the square in the Import A CD window and it will be assigned to the album in My Library.In my experience (at least for the albums in my collection) this happens about 1 time in 10.Thats what I did, But If there wasn't a image I dragged and dropped a normal jpg image of the album (after I donloaded it) onto the album title... It works that way too!Tracy Byrd Greatest hits gave me the wrong cover so I downloaded the jpg and dragged and dropped it from My Docs Folder! It works the same! Quote Link to comment Share on other sites More sharing options...
Richard Posted April 13, 2006 Report Share Posted April 13, 2006 Thats what I did, But If there wasn't a image I dragged and dropped a normal jpg image of the album (after I donloaded it) onto the album title... It works that way too!Tracy Byrd Greatest hits gave me the wrong cover so I downloaded the jpg and dragged and dropped it from My Docs Folder! It works the same! Yes of course, the manual option is also the other method to get them in. This is what I usually use too. Quote Link to comment Share on other sites More sharing options...
bogon07 Posted April 13, 2006 Report Share Posted April 13, 2006 A couple of years ago I downloaded an MP3 "GrimReverb" by Elivis Can't Surf and was surprised to see that it had album art encoded in it which was visible when loaded in SS3.4 Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted April 13, 2006 Author Report Share Posted April 13, 2006 MP3's?I know that the atrac3 files from Connect have...(I have used that beofre) Quote Link to comment Share on other sites More sharing options...
