danielbb90 Posted June 16, 2006 Report Share Posted June 16, 2006 Just tried atrac3plus 256kbps... Why have I been using 64kbps? It sounds GREAT!!!!!Just it does use alot of space and power!!I don't dare try to use the 352kbps...I dread to think the amount of space and power that will use!!!Can anyone tell me the lifespan of the MZ-NH1's battery with 352kbps?Thanks Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 16, 2006 Report Share Posted June 16, 2006 the NH1 will also be able to use 192kbps and this is pretty good as well and a bit smaller than HiSPunfortunately only accessible through SS (not SB) but it could be a good alternative Quote Link to comment Share on other sites More sharing options...
Top Cat Posted June 16, 2006 Report Share Posted June 16, 2006 Yes, 192 kbps A3+ is great - 10 hours of very acceptable sound on one disc Quote Link to comment Share on other sites More sharing options...
Tunster Posted June 16, 2006 Report Share Posted June 16, 2006 the NH1 will also be able to use 192kbps and this is pretty good as well and a bit smaller than HiSPunfortunately only accessible through SS (not SB) but it could be a good alternative192kbps is absolutely brill for saving space but keeping quality. So far, I've got 8/9 albums on a 1GB disc at 192kbps ripped from CD, and I still have 40% of space left. Very impressed so far coming back to MD and being a HiMD virgin, lol. Quote Link to comment Share on other sites More sharing options...
Skradgee Posted June 16, 2006 Report Share Posted June 16, 2006 192kbps sounds noticibly weak on high-end frequencies to me. Yeah, you can adjust that with EQ but I don't care for it. 132kbps or 256kbps is how I roll. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 16, 2006 Report Share Posted June 16, 2006 (edited) wow, I've gotta check that skradg... I had almost convinced myself the hassle of going through SS was worth the bit of extra space... still, if it diminishes SQ notably I won't!just cause of the ease of use I'm strictly using SB for PC -> MD (SS is an upload only tool for me) and therefore I'm currently only using HiSP (256) and LP2 (132) as well... even though I rarely use the latter as I think I can hear too much difference (still good for a couple of quick old-reformatted 80 min discs though ) Edited June 16, 2006 by The Low Volta Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 16, 2006 Author Report Share Posted June 16, 2006 The only problem I have is that the 256kbps sometimes leaves me in the 74(80)min discs with a couple of minuets cut off the end...and 192 leaves me with LOADS of space useless left on the disc...I don't like splitting discs, do you know if there is a solution? Quote Link to comment Share on other sites More sharing options...
Richard Posted June 16, 2006 Report Share Posted June 16, 2006 The only problem I have is that the 256kbps sometimes leaves me in the 74(80)min discs with a couple of minuets cut off the end...and 192 leaves me with LOADS of space useless left on the disc...I don't like splitting discs, do you know if there is a solution? Assuming the discs don't have to be gapless, what you can do is transfer (or try to transfer) all tracks at 256 and if the last one or two don't fit on, re-rip them at 192. Could take a bit longer I know... Quote Link to comment Share on other sites More sharing options...
danielbb90 Posted June 16, 2006 Author Report Share Posted June 16, 2006 Thanks for the infomation...I mainly use my Minidisc player for travel and you can't tell the quality...I kinda am thinking that that extra space and less power would be a useless waste?Right, anyway when I'm at home, well with my laptop I use high-quality MP3's (VBR)...I guess 64 seems reasonable for that - thinking about it so does 48! Quote Link to comment Share on other sites More sharing options...
