Sponges for RH10 earphones?
Sony_Fan
in Europe stores like Mediamarkt (I guess something like your radioshack) sells those 'sponges' really cheap, by the dozen a pack so you never have to worry about ripping one ever again :lol:
still... why not invest some $25 in better headphones? this would 'cure' your everlaaaaaasting 'lack of bass'-disease as well perhaps (read the 'best headphones under $100 thread' as there are quite a few mentioned that would please bass-heads
I did try better earphones from Sony that were $40 at BestBuy. They had this dome shape to deliver more bass. Guess what? No bass at all, and I had to raise the volume way up to hear the music. Sorry, but i don't think Sony knows what bass is. Besides, the unit itself lacks bass. So buying more expensive earphones won't do much.
Sony, add this to the RH1: MEGABASS
look Chris, I ain't going to start the bass discussion over again... but you really should learn to read what is written :P
-> I didn't say 'better SONY headphones'... I only know the Sony stockbuds, but those do not give me any faith in their ability to produce headphones :lol: why not another brand? (panasonic, ATH, Sennheiser, koss,... as I said, read the thread I mentioned as it reviews a lot of makes/models)
besides there are options besides Megabass to get a lot of (well enough for music-loving ppl) bass out of the Sony HiMDs (for ppl interested, see greenmachines thread on eq-settings for bass gain) but you do not seem to believe in them (I've given up that discussion) AND more importantly... there is more to music than bass!
Those EQ settings don't work. If Sony can add Megabass to it's tape and CD players, it SHOULD do the same for Hi-MD. There is no excuse to not have it.
Sony, more BASS!!!!
Err, I thought this is about finding the earbud foams? Or sponge?
Anyway, in-ear canal phones will usually have better bass than regular earbuds. However, there are NO earbuds that can compare to a full fledge headphone. If you want bass, get the Sennheiser HD212pro headphone. It's a good point to start, and cheap too.
  atrain said:
i'd say koss porta pros myself but yeah better headphones will improve all aspects of sound, including bass
I don't want to use headphones, that's so 90's. I prefer to use earphones, and yeah i still need the sponges. I'll check them out at Radio Shack.
...if anything, 90s were the decade of earphones.
Just speaking up against the misrepresentation of the nineties :P
Only in (relatively) recent times have headphones even had a chance to be worn without being laughed off the street. Ahh, trends...fascinating things.
and letting 'so 90s' (especially when misused as tekdroid indicated) stand between you and audio-bliss is ... well 'so childish' :P
besides, in-ear phones do deliver better bass and do not look like headphones... and the panasonic RP-JE50 in-ear phones are only $25 so not that expensive either
PS: I never said 'more expensive phones give more bass'... I did say that some phones are known to suit bass-heads, that a few of those have been reviewed in the 'best headphones under $100' and other headphone review threads here on MDCF and that the ultimately-cheap (i.e. free with the player) stockbuds will NOT deliver good sound (whether you're a bass head or not, they just plain and simply suck beyond belief... and this is no Sony thing, it's true for all stockbuds I have had the chance to try)
Sorry, but I used the RH10 earphones on my Sharp MD player with X-Bass, and what a difference! Even with cheap earphones, the bass kicks. So it is a Sony issue, they don't know what bass is.
You know, I'd like to know that "better phones" you purchased with Dome shape. It sounds like you got yourself a pair of EX51/71s, which has overpowering bass if anything else. And if that is the phone you purchased, then you're not getting the bass you want because of poor fit--those phones require a good fit with your ear canals for best Bass response.
I have to guess you got yourself a pair of EX51s by the price of things, but without more detail, I can't say. If you had gotten a pair of earbuds for $40, it'd be something akin to E868s, a pair of earbuds that are known to rival full sized headphones of that price range.
Try other bud types that came with the headphones and make sure that you get a good seal. Otherwise, you're getting less than ideal volume out of those.
Trust me, the EX51s have more than enough bass.
They were the EX51, and did not have enough bass. On top of that, I had to raise the volume up higher than with other earphones. So it has no power either.
Then you definitely don't have a good seal. Change the silicone tip to one that fit you ear canal so they are snug fit, not loose. Canal phones with good fit blocks outside noise, so you don't actually have to up the volume. Either that or you got a defective bud.
But also bear in mind the ex71 / 51 are fairly high impedance so they will sound a bit quiter compared to other lower impedance phones at the same volume.
The EX71/51s definiately packs a punch even with the underwhelming 5mW+5mW Sony Amps. Trust me, he's not getting a good seal or using undersized tips.
And 16 ohms is not high impedance, not at all, considering that even the V6 (60 ohms) can pump out decent volume with portable Sony gear. In this case, the problem is getting a good seal.
