zahne Posted November 19, 2012 Report Share Posted November 19, 2012 If Sony approached you and said we're bringing back the minidisc (suspend disbelief or ignore this post) what should the line up be? What features are you looking for? What would be your ultimate MD unit or line of units? Can be a riff or an innovation on an existing one. And to make things a little creative, how about features that could be technologically possible. Quote Link to comment Share on other sites More sharing options...
ShriDurga Posted November 19, 2012 Report Share Posted November 19, 2012 The worst thing about MD is Sonic Stage. If you are travelling for long periods, MD is fairly useless for acquiring new music unless you also happen to have a computer with SS installed. So some kind of drag-and-drop feature would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
philippeb Posted November 19, 2012 Report Share Posted November 19, 2012 On 11/19/2012 at 1:52 AM, zahne said: If Sony approached you and said we're bringing back the minidisc (suspend disbelief or ignore this post) what should the line up be? What features are you looking for? What would be your ultimate MD unit or line of units? Can be a riff or an innovation on an existing one. And to make things a little creative, how about features that could be technologically possible. My MD dream : a DCM-W1 deck, functionally equivalent to the MDS-W1, that would operate on MD DATA2 discs (the MD View discs used by the DCM-M1 camcorder). Quote Link to comment Share on other sites More sharing options...
zahne Posted November 19, 2012 Author Report Share Posted November 19, 2012 For me it would be higher density Hi-MD discs. Ones that could a lot of storage but also could hold support H.264 video playback in HD. More importantly, though, developing an MD deck designed for audio and other data archiving. That would be fantastic. HDD and flash memory both have their usage faults and can get really pricey. I've never had an issue with MDs and backing up audio. The quality isn't the same but when all the drives crash, I always have the MD version. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted November 19, 2012 Report Share Posted November 19, 2012 Said it before, but I'd like a Hi-MD version of the MZ-B10, i.e. portable with built in speaker and mics, pitch/speed control, running off AA batteries. Improvements on the B10 would include shuffle playback, EQ and uploading capabilities. Quote Link to comment Share on other sites More sharing options...
febed01 Posted November 21, 2012 Report Share Posted November 21, 2012 I would like it to be more an evolution than a revolution. It should at least keep the best of the MD platform (sound quality, disc format, long battery life, field recording ability, editing functions, standalone sound system (ie you basicaly don't need a computer)), so not a wifi-tablet-HomeCinema-MD So, here are my specs request (Sony, Sharp, Panasonic... please read this ) : DecksHi-MD support, of courseFor the rest I don't really know, I don't use them a lot (and plan to sell my Sony 520) Portable devicesBackward compatibility with SP/LP/HiMDHi quality electronics (not like on today's players)Keeping long battery life (so no hungry touch color screen or wireless networking)Keeping standalone editing functionsEasily replacable batteries (ok for AA/AAA size, so you can use the unit ages after the gumstick batteries ceases to exist on the face of the earth)4 or 8 GB discsFLAC support (at least playback)PCM recording up to 24bits/96KHzkeeping line-in optical-in mic-in ; line-out slotsoptical-outon-demand screen backlight (like on most remote controllers)can stand falling on the floor without breaking2nd phone slot (like on Sony R-70)(and speaking of R-70) quite silent motormotor/manipulations noises removing algorithm while recording (can be set on/off) Remote controllersturdier"anti-knot" coated cable (like on some headphones like the Porta-pro by Koss) SoftwareMulti-platform (same UI & features on Windows, Linux, Mac)Easier import/export/conversionNo transfer limit for audio recorded by the unit[troll]No root-kit inside[/troll] AccessoriesConverter to use the new MD unit with amps made to be used with iPodsBetter stereo portable micsCan use bluetooth or USB keyboards for names editing (if you don't have access to your computer (on holidays) of if some policies prevents you to install the MD software (at workplace)). Converter maybe included in a cradle, for instance (so you won't have a bluetooth signal sucking your batteries) Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted November 22, 2012 Report Share Posted November 22, 2012 I don't think that I need 4 or 8gb discs... 1Gb is enough for me. Real 24bit Optical out on a Hi-MD deck unit, yes Quote Link to comment Share on other sites More sharing options...
PsychoPimpKiller Posted November 23, 2012 Report Share Posted November 23, 2012 I think that an MZ-RH1 or MZ-NH900 (with a back-lit or OLED display) type of machine that would use the Blu-Ray technology would be pretty nice. You could have up to 4GB or 8GB or possibly more. That would mean over 5 hours of PCM recording on one disc. To run on AA batteries would be a major plus, too. It would never happen but there is nothing wrong with dreaming. Quote Link to comment Share on other sites More sharing options...
sfbp Posted November 24, 2012 Report Share Posted November 24, 2012 I'm not sure that the MD technology will work any more dense than what it does. As it is you're (heating and) inverting zones of metal oxide at a pretty fine separation. I agree that BluRay obviously is using much smaller physical areas per bit. However that is with a different technology. There's no equivalent to MD in the world of CD/CDR/DVD/Bluray, I think. I'm not sure what the mini-DVD camcorders do (is it even rewriteable???) - but I'm pretty sure it's not the same as MD-MO. Quote Link to comment Share on other sites More sharing options...
zahne Posted November 24, 2012 Author Report Share Posted November 24, 2012 I'm sure if Sony wanted to, they could design a BluRay Minidisc that is backwards compatible for old Hi-MD and regular MD. 8GB Hi-MD+ discs would be awesome. Most people wouldn't need more than one or two. Quote Link to comment Share on other sites More sharing options...
Rubber131186 Posted November 27, 2012 Report Share Posted November 27, 2012 What about firmware updates to add newer Atrack and other sound formats. Reflashing a messed up unit kinda like restoring a phone. I like the optical out thought. The drag and drop of music files is good too. Quote Link to comment Share on other sites More sharing options...
zahne Posted November 27, 2012 Author Report Share Posted November 27, 2012 Speaking of which, has there been attempts at making an open source alternative to Sonic Stage? Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted November 28, 2012 Report Share Posted November 28, 2012 big question... Quote Link to comment Share on other sites More sharing options...
zahne Posted December 2, 2012 Author Report Share Posted December 2, 2012 I wonder if this is something that could be added to DoubleTwist. Quote Link to comment Share on other sites More sharing options...
eastbayarb Posted December 10, 2012 Report Share Posted December 10, 2012 I would like to see a multitrack recorder that uses Hi-MD discs. I would also like to see a USB data drive that was compatible with all versions of minidisc. Quote Link to comment Share on other sites More sharing options...
gidionnz Posted December 30, 2012 Report Share Posted December 30, 2012 RH1 but than with armor and steel platting and a bigger screen. Quote Link to comment Share on other sites More sharing options...
