Which portable (any make and model) has the nicest headphone output?
Soundbox
We all know the different portables have all different headphone output sound - but which one do you like?
I am talking about directly powered headphones - not using a seperate amplifier.
The nicest to my ears is the Sony MZ-NH700. Without using bass boost or effects it gives a clean and neutral sound that works with all music types. I don't use in-ear headphones but a set of 1990's JVC 'on the ear' larger ones. These give better bass anyway.
So what model do you think has the most appealing sound from the headphone socket?
Last night I listened to a pre-recorded MD (Massive Attack - "Blue Lines") that I put onto an audio cassette. I played it on my Sony Walkman D6C and to my ears at least that machine has a superb headphone output. It sounds like listening to the headphone output on a full size MD deck with bass energy that is almost limitless. I wonder why such a headphone amp was not used on their MD portables?
My ranking of the units I own:
1. MZ-E900
2. MZ-NH700, MZ-RH710 and MZ-NH600 (not much difference in SQ)
3. MZ-NH1
4. MZ-RH910
I use the MZ-RH1 only connected to my PC to put music on the discs.
The MZ-DH10P has good SQ but the battery is very soon empty and the nice screen is mostly dark so I almost don't use this unit.
According to my hearing which may not be perfect or trained for this technical comparison, I also find the two models the MZ-NHF800 (similar to MZ-NH700) and MZ-RH710 which I own to be very similar in sound quality at Hi-SP (256) using my Sennheiser HD 280 Pro. I also believe that 352kps sounds a bit better on my MZ-NHF800 than on the MZ-RH710. Since my MZ-NHF800 is my commuter unit it could be that my hearing is accustomed (bias) towards the analog amp of the MZ-NHF800 instead of the digital one on the MZ-RH710. This is just my observation.
