Bob Shade Posted October 23, 2018 Report Share Posted October 23, 2018 I have a stack of discs of my music recorded live from a while back.. Some of them play, a bunch read blank and the largest pile don't playback at all. These ones read that tracks exist but when I push play the display reads LP: at the top and below that the track number and time. The track looks like it is playing as the clock is counting down the time played but nothing out of the speakers.. I am running analog out>amp>speakers Will these units play the LP format. The discs were recorded on a Sony Minidisc Walkman Thanks. Quote Link to comment Share on other sites More sharing options...
sfbp Posted October 23, 2018 Report Share Posted October 23, 2018 Sorry, but the MDS-JE520 will not play MDLP disks. That's why you see the LP: sign. You need at a bare minimum, an MDS-JE440 (-640 would be better). Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted October 24, 2018 Report Share Posted October 24, 2018 Hi Bob Shade, more details here : http://www.minidisc.org/part_Sony_MDS-JE520+S39.html Maybe you had recorded all your live music with a MDLP portable unit, your " Sony Minidisc Walkman" (this is generic name for ALL Sony portable units : CD, MD, MP3, etc). All SP only decks (what us we call 1st generation), like the JE520 cannot read MDLP format as said Stephen (sfbp). The good news is that there are plenty of decks or portable units which play MDLP on the web markd is MDLP, then Net-MD, then Hi-MDet. Minidisc.org will give you their model names. To be complete, the best you can get is MDLP with "type S". Do you want to know more about MD portable units history ? https://sites.google.com/site/crazyforminidisc/ 1 Quote Link to comment Share on other sites More sharing options...
Larry NYC Posted April 6, 2020 Report Share Posted April 6, 2020 On 10/23/2018 at 4:32 PM, sfbp said: Sorry, but the MDS-JE520 will not play MDLP disks. That's why you see the LP: sign. You need at a bare minimum, an MDS-JE440 (-640 would be better). Can't you guys just talk 74 min and 80 min Discs? Quote Link to comment Share on other sites More sharing options...
Larry NYC Posted April 6, 2020 Report Share Posted April 6, 2020 None of my 74 min and 80 Min Discs are marked with MDLP or otherwise. Yes Im a noob and I need to know the difference. Please , thank you Quote Link to comment Share on other sites More sharing options...
BearBoy Posted April 6, 2020 Report Share Posted April 6, 2020 Blank discs are not MDLP or otherwise - it is the encoding method that is using whilst recording to the discs that could be MDLP. Blank discs will hold 74 or 80 minutes of SP (standard) quality recordings (there were also 60 minute blank discs in the earlier years). Later players had the ability to record in long play mode (known as MDLP) so you could get more music on a 74 minute or 80 minute disc. There are two MDLP modes on standard MD (i.e. not HiMD): LP2 - will give you twice the recording time as SP (so 160 minutes on an 80 minute disc or 148 minutes on a 74 minute disc) LP4 - will give you four times the recording time as SP (so 320 minutes on an 80 minute disc or 296 minutes on a 74 minute disc) If you try to play a disc with MDLP recordings on a player that is not MDLP compatible then you will just get silence. Quote Link to comment Share on other sites More sharing options...
BearBoy Posted April 6, 2020 Report Share Posted April 6, 2020 There's an FAQ over on MiniDisc.org that might help explain things in a bit more detail: http://minidisc.org/mdlpfaq.html Quote Link to comment Share on other sites More sharing options...
