Kona702 Posted February 20, 2013 Report Share Posted February 20, 2013 Hello friends, Has anyone noticed the striking crappiness of MP3 files transferred "as-is" to a HI-MD? Meaning rather than converting the MP3 file to Atrac3Plus, the RH-10 can transfer MP3's with no conversion and play them back. I am confused as to why the native format of an MP3 file sounds horrible compared to the same file converted to a different format? An MP3 converted while transferring to the HI-MD Atrac3Plus 352kbps sounds amazing compared to if you just simply transferred the MP3. I don't understand why, it makes no sense to me that it would sound better as the originating file is the MP3. I'm assuming it has something to do with the playback on the MD unit (using an RH-10 for the comparison) Can anyone enlighten me? Input is appreciated! Thanks, Sean Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 20, 2013 Report Share Posted February 20, 2013 It's just a known problem the second generation HiMD units (M10/100, RH10/910, ?RH710, ?DH710). People have speculated why, but my sense is that Sony had not yet mastered the technology at that point. Subsequently their MP3 support improved including their conversion FROM Atrac to MP3 which they released as a "goodbye" present. I have yet to hear any conversion where having ATRAC3+ 352 makes a significant difference over 256. However going the other direction, it's essential to convert ATRAC3 (66 and 132kbps) to at least MP3 256kbps, because ATRAC does a much better job of compression than MP3. Quote Link to comment Share on other sites More sharing options...
THIS SUCKS Posted February 20, 2013 Report Share Posted February 20, 2013 no. it has been docmented before. sony did it on purpose to promote their own atrac codec as superior to mp3. just convert all your mp3's to atrac and the will sound great all the time. Quote Link to comment Share on other sites More sharing options...
Sony_Fan Posted February 20, 2013 Report Share Posted February 20, 2013 If you play these MP3s on an MZ-RH1, they will sound normal and they will not be crippled like on the RH10. That's one of the unique things about the RH1, MP3s sound great! Quote Link to comment Share on other sites More sharing options...
Kona702 Posted February 21, 2013 Author Report Share Posted February 21, 2013 Thanks everyone! I was just making sure it wasn't me. Quote Link to comment Share on other sites More sharing options...
