GYM | Network Walkman BROWSER-PLAYER-EXTRACTOR
xispe
  • Replies 523
  • Created
  • Last Reply
Top Posters In This Topic
Ok! Here you have your answer...
Each player has it's own set of keys, so you can't use the keys generated in one player to decode tracks in other player.
If you have 2 players, you need to have 2 instances of GYM separated, and "assing" each one to one player. Use key wizard to generate the keys for each of the players.
The genre, artist and albums info is not encrypted so you should see them without the correct set of keys.
Joke: Then you can tag each player with a marker GYM1, and GYM2, to see which GYM to use to play and extract the files :D
I wondered about that - but with seeing the artist name etc I focused too much on other potential problems - cheers I have even greater flexibility now.
Just uploaded this to my new A3000 using ltmayonaise's instructions. I haven't tried it yet as I'm now uploading my library to the player.
Just wondering, as MP3manager doesn't support the A3000 is there any need to have it installed once all the keys have been generated, along the same lines is there any need to have the keygeneraterwizard on the player too, could I just delete them, I'd like to have it as tidy as possible after all it is new :)
As long as you have the keys generated, no need for carrying around the keywizard. You just need GYM.exe, those DLLs and decodeKeys.dat files. You can keep encodeKeys.dat for future releases, if you know what I mean. But for that I need all your help :ol_cool:
Hi Xispe, for the first time ver. 1.12 worked with me. No more empty folders when you try to save. Works like a charm with my HD5. Though I had to copy the 2 .dat files to 1.12 folder from the previous one to be able to make it work. I am transfering with vaio music transfer and they play fine and am able to save them.
Best
Small update on my end, downloaded version 1.12, and hooked up the A3000.
Note, i don't have SS nor the mp3 manager installed. all files now are appearing as mp3 in the window below which is a good sign indeed, but downloading files still doesn't work, empty folders sadly. Looking forward to newer versions in the future.
btw, how hard would it be to create a program that just uploads the mp3s to the player and ads OMG encryption to the files?
Ok, great, so to confirm I can delete the folder with the mp3manager in it, the keywizard, and the crack.mp3 file
Ok it appears to run fine, only little thing is that the new A**** support wma files. These now appear in GYM as adtrac files. I assume the programme wont work with these but it would be nice if it identified them correctly so there was no confusion.
Another tiny glitch is although I've downloaded the most recent version from the website 1.12 the little splash page that comes up on intialization says its 1.11
I want to say a big thank you to firstly xispe for this fantastic piece of software, truly inspired, and then secondly to everyone else who is helping develop it. This is a great project that solves one of the 'Sony' problems.
For us new A**** the only problem at the moment is that we cant use MP3FileManager :( and we're still stuck in SonicStage hell. I'm hoping that oneday this software will be able to be a complete package that will replace it, maybe thats asking a bit much but I can always hope.
Please keep up the good work folks, everybodies lovin ya for it
Not sure the new units support WMA yet, will soon though.
Why use SS, when CP works fine and allows you to take advantage of all the players functions.
Oh nOOOOOOOOOOOOOOOOO disaster, the player doesn't work through the headphones or lineout :ol_cry::ol_cry: all that comes out is white noise
I'm using the firmware update 1.01 from the front pages here
I need it to work as a walkman first and foremost, guess I'm going to have to initialise the disk and start again.
The reason I'm not using connectplayer is to start off with it wouldn't upload music to my player which was far from ideal, in a fit of pique I de installed it, I went to instal it again and since doing that it won't run. I've spoken to sony about it and they say its a known problem for which there is no solution at the moment, hopefully it will be sorted with the next release of CP. I'm not going to hold my breath
Mine seems to, uploads via SS and plays fine. SS won't upload any tracks that have copyright protection to the player but will play them through the computer fine
I think that all that is required for GYM is to correctly recognise file types
Edited by iggs
The character '&' is not correctly displayed in the playing panel,
but right in the track list and in the playing list  :ol_glance:
Yes, in labels you need to put && to display represent a single &.
The & in windows forms is used to identify the character which shall be underlined for keybord shortcuts...
for instance:
&File = File
Bla && Bla = Bla & Bla
Thanks vovo! :ol_biggrin:
It seems to be really nice stuff but i'm unable to run it properly - with everything installed my gym 1.0 runs but won't play or do anything, displaying the
unhandled error message, which i can skip but nothing happens (nothing works)
I dunno whether this is going to help but here are the details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Lister.Classes.PlayQueue.Play()
at Lister.MainForm.pb_Play_Pause_MouseDown(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows.0/microsoft.net/framework/v1.1.4322/mscorlib.dll
GYM
Assembly Version: 1.0.2143.22909
Win32 Version: 1.0.2143.22909
CodeBase: file:///D:/Downloads/flock/GYM1.0/GYM1.0/GYM.exe
CodeBase: file:///c:/windows.0/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows.0/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows.0/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
System.Xml
CodeBase: file:///c:/windows.0/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
CSSound
Assembly Version: 1.0.2143.22689
Win32 Version: 1.0.2143.22689
CodeBase: file:///D:/Downloads/flock/GYM1.0/GYM1.0/CSSound.DLL
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
And versions 1.1 and 1.2 just keep popping unhandled exceptions and when i press skip it just pops up again.
Details:
at GYM.MainForm.t_Update_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
My system is !RUSSIAN! could that be the problem? Otherwise,
I'm running a winxp sp2 with .net 2.0 and don't really have any problems with running any other stuff
Do you have directx installed on your computer ?
Spasibo! :)
I don't use atrac and i'm not going to.
9с...
Oh boy i want to run this stuff - i've been hoping someone'd make something like this someday...
Maybe someone's working on the firmware? I would really love using simple folder - onto - player copying and (or at least) folders instead of artists, since the lettter search works only for songs... on a 20gb walkman...... :ol_shocked:
Or is that impossible?
dammit, sony is simply psycho. Plus i had to increase the sound level manually, through the service menu. This isn't too much of a user-ready product i'd say but oh whatever... (i'm not an old fart actually but i like to to a lot of complaining :ol_sick: )
Otherwise, my hd5 makes a great gizmo... (which i can't really say because the soft side of it sucks ass...) :ol_dead:
Edited by gabdag
Hi.
After a while of file analysys :
About 03GINF01.DAT
format is similar to 04CNTINF.DAT one :
04CNTINF.DAT (for each track) format was (and is !!)
TIT2, Track Title
TPE1, Artist Name
TALB, Album Title
TCON, Gender
TSOP, ?
03GINFxx.DAT (for each album)
TIT2, Album Title
TPE1, Artist Name
TCON, Gender
TSOP, ?
PICP, Main Picture P0 (path + file name)
PIC0, Tiny pictures (path + file name) "; separated"
Notes :
- I linked my picture under sonic stage, and even for my HD5, every pictures
are copied and present on my HD5 hard drive.
- Pictures are Linked for album only. I don't know where it is stored
for pictures linked with tracks.
- An additional number is provided is PICP entry (with the file name)
Don't know its meaning.
It should not be that hard to include picture display now,
just add a ReadAlbums_(string sourceFilename) method to your GYM object.
I did a little test program based on your code, just for check, it works nice,
file stored are jpg, so you can even directly use the Load method from the pictureBox object in C#.
But don't have enough time to make release version. Sorry.
Okay, you still need sonic stage to use this feature, but some ATRAC device user with display will love to retrieve their sleeves...
i'm in touch with vovo, he said he'll be looking at this pretty soon.
have a nice day
Hello everybody
I found a bug and correct it, it was the one who prevent mp3 playing and saving
in certain cases. It was about pictures in oma files...
Now i finish a new build with covers display :ol_biggrin:
That works but the bad thing is that files need to be uploaded
with covers by SS :ol_cry:
Bye
A little preview
And now a beta for testing, and specially for those who had problems
for playing and saving mp3. :ol_groucho:
GYM beta only for testing and feedback
The covers are added, the localization is in progress.
To add covers, you must use SS, add covers in SS (only to albums, to tracks
it's useless) and have to to reupload albums to the HD.
Bye
modif1.1
Edited by Vovo
When attempting to run keywizard, I get the following. Any ideas?
An unhandled exception has occurred in your application... blah blah blah...
File or asseembly name Common, or one of it's dependencies, was not found.
System.IO.FileNotFoundException: File or assembly name Common, or one of its dependencies, was not found.
File name: "Common"
at KeyWizard.KeyWizardForm.StartupCheck()
at KeyWizard.KeyWizardForm.PrepareStep(Int32 stepNumber)
at KeyWizard.KeyWizardForm.bt_Next_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
=== Pre-bind state information ===
LOG: DisplayName = Common, Version=1.0.2171.30027, Culture=neutral, PublicKeyToken=null
(Fully-specified)
LOG: Appbase = C:\Documents and Settings\Administrator\Desktop\JJ\
LOG: Initial PrivatePath = NULL
Calling assembly : KeyWizard, Version=1.0.2171.30027, Culture=neutral, PublicKeyToken=null.
LOG: Policy not being applied to reference at this time (private, custom, partial, or location-based assembly bind).
LOG: Post-policy reference: Common, Version=1.0.2171.30027, Culture=neutral, PublicKeyToken=null
LOG: Attempting download of new URL file:///C:/Documents and Settings/Administrator/Desktop/JJ/Common.DLL.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Administrator/Desktop/JJ/Common/Common.DLL.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Administrator/Desktop/JJ/Common.EXE.
LOG: Attempting download of new URL file:///C:/Documents and Settings/Administrator/Desktop/JJ/Common/Common.EXE.
mscorlib
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
KeyWizard
Assembly Version: 1.0.2171.30027
Win32 Version: 1.0.2171.30027
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Desktop/JJ/KeyWizard.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
enabled.
For example:
<configuration>
</configuration>
Then I continue anyway and get this:
Another unhandled exception.
Could not find file "C:\Documents and Settings\Administrator\Desktop\JJ\crack.mp3".
System.IO.FileNotFoundException: Could not find file "C:\Documents and Settings\Administrator\Desktop\JJ\crack.mp3".
File name: "C:\Documents and Settings\Administrator\Desktop\JJ\crack.mp3"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode)
at KeyWizard.KeyWizardForm.ProcessStep(Int32 stepNumber)
mscorlib
KeyWizard
System
System.Drawing
enabled.
For example:
<configuration>
</configuration>
I continue again and get to the "generating temp files" screen, but it does nothing.
Bye
modif1.1
While it looks great IMHO your going down the wrong road here. The big advantage of this software is it eliminates the need for SS on players that mp3manager works on and the software is nice and 'lite' focusing on what is important.
Ian
Ian
Yes i think about it, it' why i'll add an option for displaying or not the covers :ol_rolleyes:
For somone (like me) who don't use SS it will be transparent, for others
if they add covers with SS thet will be displayed.
Bye
Yesterday i found this beautiful piece of software... GYM. It works perfect on my HD3.
I realy like the way GYM looks and works... I like it so much that i realy would like to use it with my MP3 files on my computer. Is there a GYM (alike) which wil work on a computer...
(p.s. Sorry for my englisch)
Sorry GYM only read MP3 on Sony player
You may try OrangeCD by Firetongue, very nice i think
Hi, I would be very thankful to anyone who can solve my problem with GYM program. The problem is next: when I start KeyWizard it always pops up the message:FAILED TO LOAD RESURCES FROM RESOURCE FILE. PLEASE CHECK YOUR SETUP. Now, I have everything needed: NET framework 1.1, GYM 1.12, MP3 File Manager... I really don't know what's the problem. Again, thanks a lot to anyone who can help me.
