dugom Posted January 11, 2006 Report Share Posted January 11, 2006 xispe said: Ok!I see that so far the GYM key generation wizard isn't going anywhere for NW-A1000 or NW-A3000 users.Connect Player simply refuses to put the crack tracks into the player...I wonder why... Meanwhile you can use Sonicstage to do the process... In sonicstage it works, because i was able to test it!Simple process:1) Install sonicstage v3.3-- RECOVERY OF UNFINISHED WIZARD SITUATION --2) Check your network walkman root folder... - If you find a folder named "OMGAUDIO backup" and no "OMGAUDIO" folder, rename "OMGAUDIO backup" to "OMGAUDIO" - If you have both a "OMGAUDIO backup" and a "OMGAUDIO" folder: - create a backup of the "OMGAUDIO" folder in your harddrive - delete "OMGAUDIO" folder - rename "OMGAUDIO backup" to "OMGAUDIO"--2) Run the KeyWizard, generate the crack mp3 files.3) When the wizard asks you about which software you will use to upload, select Sonicstage and clic Next.4) Open Sonicstage5) Import the tmp folder inside the directory of GYM.6) Transfer all the imported tracks to the device.7) Shutdown Sonicstage8) Follow on with the wizard until the end.Like this Keywizard will work.This process is a resumed version of what is explained here:http://www.atraclife.com/forums/index.php?showtopic=773Try it out...Did you get the same feedback from another user ? or is it just from my experience ? because it is very possible that I'm doing something wrong somewhere and that somebody else suceded in transfring the cracks. Quote Link to comment Share on other sites More sharing options...
sh33p Posted January 11, 2006 Report Share Posted January 11, 2006 Has anyone succeeded with GYM and MP3FM in importing the cracks to NWA3k? Xispe if SonicStage is used to import the cracks, is CONNECT Player still useable? Quote Link to comment Share on other sites More sharing options...
xispe Posted January 11, 2006 Author Report Share Posted January 11, 2006 sh33p said: Has anyone succeeded with GYM and MP3FM in importing the cracks to NWA3k? Xispe if SonicStage is used to import the cracks, is CONNECT Player still useable?I see no reason for CONNECT player to be usable after importing tracks with sonicstage. Your previous database is backed up and restored at the end of the wizard, so everything should go fine. dugom said: Did you get the same feedback from another user ? or is it just from my experience ? because it is very possible that I'm doing something wrong somewhere and that somebody else suceded in transfring the cracks.Transfering the crack*.mp3 tracks by using Connect simply doesn't work. A lot of users are having problems, that's why I advised to use Sonicstage to transfer these tracks. Quote Link to comment Share on other sites More sharing options...
sh33p Posted January 11, 2006 Report Share Posted January 11, 2006 (edited) xispe said: Hello! As there are a lot of users with the new A series of walkmans, i'm trying to fix the keywizard so that is possible to use sonicstage or connect player for the key generation process.This means that this will help people a lot, as they won't have to fake that there is a MP3 File Manager installed and stuff like that..What we have is a player without any database (no OMGAUDIO, since the original was renamed) and all the crack.mp3 tracks inside the tmp folder. What we need is simply write this files into the walkman, so that the wizard can look for the keys. So, now we are supposed to do this with MP3 File Manager, Sonicstage or Connect. In the case of MP3 File Manager, the scenario is simple.. just drag the files. As for Sonicstage or Connect it is necessary to add the files into the library, and then transfer them as is. (and remove them from the library, not to keep all that trash...)My question is that... for the new A players, why can't we use connect directly ?I saw in Ltmayonnaise instructions that:"This whole GYM installation process will only work using Sonic Stage, but before you scream… Ohhhh but I wont be able to use my artist link! I was able to get it working with Connect Player after getting GYM installed."fromhttp://www.gaugestudios.com/nwa1000/I am thinking on a much more simpler process:"Transfer MP3 Files with Sonicstage or Connect Player1. Import all the files in the tmp folder and subfolders to your library;2. Transfer all the files to the player (AS IS, without converting them into ATRAC);3. Delete from your library all the tracks added in step 1.4. Close Sonicstage / Connect Player"Isn't this enough ?Does the OMGAUDIO directory structure created in Connect is different than the one created with Sonicstage ?Thanks!Not at this time.But! for next release we will have bookmark edition and playlist creation / edition!It works! err... these icons look very japanese In the http://www.gaugestudios.com/nwa1000/ guide it says if we use SS to import music then CP won't recognise the A3000 anymore. has that been fixed?Using Sonicstage to move the cracks to my player I got a Microsoft Visual C++ Runtime Library error omgjbox.exe has "Requested runtime to terminate it in an unusual way" at 99%.... Edited January 11, 2006 by sh33p Quote Link to comment Share on other sites More sharing options...
TheBo84 Posted January 11, 2006 Report Share Posted January 11, 2006 HI, i'm looking for an alternative for SS 3.1. I own a NW-E75 iwould try GYM but i think it is not compatible with my device, any suggest?Thanks in advance for ur courtesy.P.S. Sorry 4 my english. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 11, 2006 Report Share Posted January 11, 2006 TheBo84 said: HI, i'm looking for an alternative for SS 3.1. I own a NW-E75 iwould try GYM but i think it is not compatible with my device, any suggest?Thanks in advance for ur courtesy.P.S. Sorry 4 my english.Have you tried Sonic Stage ver3.3??It is far more stable than Sonic Stage ver3.1 Quote Link to comment Share on other sites More sharing options...
sh33p Posted January 11, 2006 Report Share Posted January 11, 2006 (edited) Well I finally got GYM to work on my NWA3000. CP is completely f***ed up though, it will crash every time I connect my NWA, or if it's already connected, after the initial Reading Data reaches 100%. As far as I'm aware, importing the crack.mp3s with CP screws it over, so it has to be done with SonicStage. I haven't gotten MP3FM to work. Edited January 11, 2006 by sh33p Quote Link to comment Share on other sites More sharing options...
Chris J Posted January 11, 2006 Report Share Posted January 11, 2006 I got GYM to work with my NW-A3000 first try.. I imported the crack tracks in SonicStage and then followed the instructions to be able to use CONNECT, I've had no problems at all!! All works really nicely.But yes, MP3FM doesn't work (but I never intended on using it anyway). Quote Link to comment Share on other sites More sharing options...
dugom Posted January 11, 2006 Report Share Posted January 11, 2006 Chris J said: I got GYM to work with my NW-A3000 first try.. I imported the crack tracks in SonicStage and then followed the instructions to be able to use CONNECT, I've had no problems at all!! All works really nicely.But yes, MP3FM doesn't work (but I never intended on using it anyway).Chris,Did you start from scratch with an empty A3000, or did you get GYM/SS to work with tunes already in the A3000 without loosing them ? Quote Link to comment Share on other sites More sharing options...
headlessmonkeydude Posted January 11, 2006 Report Share Posted January 11, 2006 thanks very much for the help i will try it out as soon as i get my NW-A back from my friends house Quote Link to comment Share on other sites More sharing options...
enifalas Posted January 11, 2006 Report Share Posted January 11, 2006 Xispe, have you considered to try to reverse-engineer the encryption algorithm instead of finding values by brute-force? It seems that someone (http://www.livejournal.com/users/waider/415461.html) has managed to do it, though I believe it is from the 1.x version of MP3FileManager. Hope it helps.Let me tell you that so far you have done a terrific job for helping all of us NW-xxx users. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
sh33p Posted January 12, 2006 Report Share Posted January 12, 2006 How do you completeley remove SonicStage and CP and start over? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 12, 2006 Report Share Posted January 12, 2006 sh33p said: How do you completeley remove SonicStage and CP and start over?First open "Add or Remove Programs " Delete all the software which are related to Connect or Sonic Stage like Soni c Stage 3.3 ,Open Mg Limited Patch ,Open Mg Secure Module etc .Now Open Registry & Delete HKEY_LOCAL_MACHINE\SOFTWARE\Sony Corporation(Be careful while doing this ).Also please don`t ask questions which are not related to the Ongoing topic .If you have any further query relating to this question ..Please start a new topic under relevant forum.& We will help you accordingly Quote Link to comment Share on other sites More sharing options...
xispe Posted January 12, 2006 Author Report Share Posted January 12, 2006 enifalas said: Xispe, have you considered to try to reverse-engineer the encryption algorithm instead of finding values by brute-force? It seems that someone (http://www.livejournal.com/users/waider/415461.html) has managed to do it, though I believe it is from the 1.x version of MP3FileManager. Hope it helps.Let me tell you that so far you have done a terrific job for helping all of us NW-xxx users. Keep up the good work!Hello, Yes, actually I have been contacted by email by someone who is helping me A LOT in that task. Hope to have something new soon. Quote Link to comment Share on other sites More sharing options...
nickzeff Posted January 12, 2006 Report Share Posted January 12, 2006 Quote Hello, Yes, actually I have been contacted by email by someone who is helping me A LOT in that task. Hope to have something new soon.I am now officially too excited for words... Quote Link to comment Share on other sites More sharing options...
Grim Santo Posted January 12, 2006 Report Share Posted January 12, 2006 If you can add support for editing MP3 ID on the player... Life would be golden.. Quote Link to comment Share on other sites More sharing options...
dugom Posted January 14, 2006 Report Share Posted January 14, 2006 dugom said: Did you get the same feedback from another user ? or is it just from my experience ? because it is very possible that I'm doing something wrong somewhere and that somebody else suceded in transfring the cracks. Sorry for asking, but could other A1000 / A3000 users tell me if using GYM1.2b they can transfer the crack*.mp3 to their player using Connect ? I can't do it and was wondering if I was alone in this situation...Thanx Quote Link to comment Share on other sites More sharing options...
iggs Posted January 15, 2006 Report Share Posted January 15, 2006 (edited) To upgrade from GYM version 1.12 to version 1.2beta which files do I have to replace?Just a suggestion but it might be worth including upgrade instuctions on the GYM homepage Edited January 15, 2006 by iggs Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 15, 2006 Report Share Posted January 15, 2006 iggs said: To upgrade from GYM version 1.12 to version 1.2beta which files do I have to replace?Just a suggestion but it might be worth including upgrade instuctions on the GYM homepageYou will again need to run Keywizard again . Quote Link to comment Share on other sites More sharing options...
iggs Posted January 15, 2006 Report Share Posted January 15, 2006 Stuge said: You will again need to run Keywizard again .I've now worked out which files to replace, the GYM.exe file and also the GYM XML file which there didn't seem to be a copy in version 1.12I'm sure I read that once the KeyWizard has been run and the database is generated then it doesn't need doing again. And to bear that out the program seems to be working fine.The playlist function is FANTASTIC. I'd given up trying to use CONNECT to do this, I haven't got days worth of time to put aside for gererating each playlist in CP.Well done folks, I'm really looking forward to seeing future releases and the features you manage to incorporate. Sony should sit up and pay attention to what it is you have managed to acheive in a relatively short space of time: fast, light, reliable and functional software. Has Sony ever managed to do this?? Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 15, 2006 Report Share Posted January 15, 2006 Today I used 1.2beta (Using Soinic Stage ) & I lost al lmy songs on my Network walkman .I think it is better to Use GYM with Mp3 file manger. Quote Link to comment Share on other sites More sharing options...
iggs Posted January 15, 2006 Report Share Posted January 15, 2006 Stuge said: Today I used 1.2beta (Using Soinic Stage ) & I lost al lmy songs on my Network walkman .I think it is better to Use GYM with Mp3 file manger.Not an option with an NWA1k or 3k. I've had no problems with upgrading to 1.2beta. I think you might have transfered to many files and deleted the databases.A set of upgrade instructions on the GYM homepage would be handy Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 15, 2006 Report Share Posted January 15, 2006 iggs said: Not an option with an NWA1k or 3k. I've had no problems with upgrading to 1.2beta. I think you might have transfered to many files and deleted the databases.A set of upgrade instructions on the GYM homepage would be handyI know all my Songs are in "OMGAUDIO backup" but now neither Gym works now & Network walkman says no Data on my Networkwalkman . VoVo & Xispe or Anybody Please help me can i do something now ..... :Edit:: Ihave put all the files of "OMGAUDIO backup" to my OMGAUDIO folder and now all my songs are again playing .Now I will again Try GYM & i WILL see were I did mistake before ... Quote Link to comment Share on other sites More sharing options...
xispe Posted January 15, 2006 Author Report Share Posted January 15, 2006 If you already had GYM 1.12 running with no problems, there is no need to run the wizard again. Simply overwrite all the files that come in the zip file. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 16, 2006 Report Share Posted January 16, 2006 xispe said: If you already had GYM 1.12 running with no problems, there is no need to run the wizard again. Simply overwrite all the files that come in the zip file.Thanks ,I will just do that .But i was basically trying Gym Keywizard with Sonic Stage option.I would Like to tell you something that whenever I try to use SonicStage ver3.3 to transfer Crack.mp3 .I got a message like "Looking for some deleted tracks .." & This message never stops until I put some music via Mp3 file manger .So During that period I was not Allowed to transfer "GYM" folder onto my player . Quote Link to comment Share on other sites More sharing options...
Vovo Posted January 16, 2006 Report Share Posted January 16, 2006 Hello XispeI send you, my work by mailsyl Quote Link to comment Share on other sites More sharing options...
lauplazas Posted January 18, 2006 Report Share Posted January 18, 2006 Hi, I tried GYM but in the midle of proccess my computer shutdown, before i tranfer the tmp files to device. Now i diconnect my nw-hd5 from USb and when it´s creating database display tha following error "Mismatch in system file". I tried to rename de OMGAUDIO backup folder to OMGAUDIO and nothing!!! MP3file manager display alll musics and sonicstage to.Any idea?????? I dont wanna loose my MP3, help me!!! Quote Link to comment Share on other sites More sharing options...
xispe Posted January 18, 2006 Author Report Share Posted January 18, 2006 lauplazas said: Hi, I tried GYM but in the midle of proccess my computer shutdown, before i tranfer the tmp files to device. Now i diconnect my nw-hd5 from USb and when it´s creating database display tha following error "Mismatch in system file". I tried to rename de OMGAUDIO backup folder to OMGAUDIO and nothing!!! MP3file manager display alll musics and sonicstage to.Any idea?????? I dont wanna loose my MP3, help me!!!Try to transfer some music into to the device using mp3fm or sonicstage, and see how the player behaves.Another solution is to run the key wizard, hope that the computer doesn't shutdowns again, generate the keys, and use GYM to save all your mp3s to your harddrive. This way you will be able then to reinitialize the device, and copy everything back into the player by using mp3fm. I did this once, after damaging the database... Quote Link to comment Share on other sites More sharing options...
lauplazas Posted January 19, 2006 Report Share Posted January 19, 2006 I tried transfer some music , but i got the same error. If i do all GYM process again, will i any chance to get my music again, once corrupet my database?? Thanks!!! Quote Link to comment Share on other sites More sharing options...
renato lima Posted January 19, 2006 Report Share Posted January 19, 2006 Man, am using NW-A3000 (AWESOME).. - I'm totally impressed by ur great program but it still need to work better with this A-series device... --i think that u r close to get a software WAYYY BETTER than the fucking connect software! !! !u just gotta find a way of killing thart wizard process... - if u need help, just tell me how i can do it!cheers Quote Link to comment Share on other sites More sharing options...
xispe Posted January 19, 2006 Author Report Share Posted January 19, 2006 lauplazas said: I tried transfer some music , but i got the same error. If i do all GYM process again, will i any chance to get my music again, once corrupet my database?? Thanks!!!If both sonicstage and mp3fm show all the tracks in the player, GYM will also be able to display, play and extract them from the player. If you want to skip the key wizard process, wait a few days, as it seems it is going to be dropped to a much better solution renato lima said: Man, am using NW-A3000 (AWESOME).. - I'm totally impressed by ur great program but it still need to work better with this A-series device... --i think that u r close to get a software WAYYY BETTER than the fucking connect software! !! !u just gotta find a way of killing thart wizard process... - if u need help, just tell me how i can do it!cheersWe are a step away of killing that wizard process. Check the other post, regarding key computation. Thanks for your support! Quote Link to comment Share on other sites More sharing options...
lauplazas Posted January 19, 2006 Report Share Posted January 19, 2006 Xispe... I got it!!! I done the process that you told me and worked very well!!! Now i got back my MP3´s and my nw-hd5 is working fine with GYM. Thanks Xispe!!! You made a happy Brazilian Guy.... Quote Link to comment Share on other sites More sharing options...
bongocanuck Posted January 20, 2006 Report Share Posted January 20, 2006 (edited) Just an update on the 1.12 beta with my Vaio pocketWorks good except the bookmark and playlist feature does not work.1) When I create a PLAYLIST in Gym and then try to listen to it in the Vaio it does notshow up at all. Perhaps it is because there is no "Playlist" category in the Vaio but I was hoping it may appear under "GROUP" category - however no such luck 2) When I add songs to the BOOKMARK sections (1 thru 5) in GYM and then attempt to view then im the vaio they do not appear at all.Regardless thanks for your work X- you are the man!But I do not think the Vaio with playlists based in the player in my fantasy will ever be a reality.Cheers Edited January 20, 2006 by bongocanuck Quote Link to comment Share on other sites More sharing options...
Vovo Posted January 20, 2006 Report Share Posted January 20, 2006 If only we've got NW-A... and Vaio it will be easiest to test...Vaio are fully compatibles for covers but for bookmarks andplaylists not so sure, a 03GINF22.DAT vaio is needed.I end a new build with new buttons and minor improvments.Bye Quote Link to comment Share on other sites More sharing options...
bongocanuck Posted January 20, 2006 Report Share Posted January 20, 2006 By "covers" do you mean album jackets? Quote Link to comment Share on other sites More sharing options...
Vovo Posted January 20, 2006 Report Share Posted January 20, 2006 Yes sure Quote Link to comment Share on other sites More sharing options...
gabiramos Posted January 20, 2006 Report Share Posted January 20, 2006 I have VAIO and it happened the same as bongocanuck.Vovo, I was doing my own research. Perhaps I am wrong, but instead of 03GINF22.DAT (which seems to be empty in VAIO), I think that the group information comes from 03GINF01.DAT.I don't know if NW-HD has same structure for groups, but perhaps Vovo you can try to work with groups as with playlist by using this 03GINF01.DAT.Please, confirm if you have some progress. I will try to have a look during the weekend (if having time)Thanks-Gabi Quote Link to comment Share on other sites More sharing options...
Vovo Posted January 21, 2006 Report Share Posted January 21, 2006 (edited) For resuming______KEYGEN__PLAYING_ COVERS__PLAYLISTS___UsingHD5_____X________X_______X_________X_________SS (for cover) - MP3FMVAIO____X________X_______X_________-_________SS (for covers) - MP3FMNWA____X_________X_______-_________-_________CONNECT -> I'm looking, a guy send me files...(Issues MP3 with covers inside)Playlist for VAIO -> strange issue, perhaps SS do something special...At yhis time a playlist made by GYM is not compatible with SS, i think when we'll find why, it will be ok for VAIO. Edited January 21, 2006 by Vovo Quote Link to comment Share on other sites More sharing options...
Vovo Posted January 21, 2006 Report Share Posted January 21, 2006 (edited) Just for fun a new beta for testing...GYM Beta 1.21 ENBye Edited January 21, 2006 by Vovo Quote Link to comment Share on other sites More sharing options...
sander151187 Posted January 21, 2006 Report Share Posted January 21, 2006 (edited) Vovo said: Just for fun a new beta for testing...GYM Beta 1.21 ENNice work, new buttons working better than the old ones.No errors experienced so far.GYM is getting better every release Edited January 21, 2006 by sander151187 Quote Link to comment Share on other sites More sharing options...
