takuhii Posted May 31, 2006 Report Share Posted May 31, 2006 Hi,I don't know if anyone else has been having the same problem, but I cannot get the web installer version of SonicStage 4.0 to install properly. It seems to have a problem with the actual SonicStage installtion bit, everything else install fine, it terminates the installation JUST before the add-on is installed, if I re-start the installtion it re-installs SonicStage and the Add-on, but doesn't generate ANY start menu options, and if I try to execute SonicStage from Windows Explorer it just sits there and doesn't open. I also had this problem with SonicStage 3.4 and gave up in the end. I have the latest version of DirectX and all necessary drivers for my PC, can anyone help??? Link to comment Share on other sites More sharing options...
Stuge Posted June 1, 2006 Report Share Posted June 1, 2006 takuhii said: Hi,I don't know if anyone else has been having the same problem, but I cannot get the web installer version of SonicStage 4.0 to install properly. It seems to have a problem with the actual SonicStage installtion bit, everything else install fine, it terminates the installation JUST before the add-on is installed, if I re-start the installtion it re-installs SonicStage and the Add-on, but doesn't generate ANY start menu options, and if I try to execute SonicStage from Windows Explorer it just sits there and doesn't open. I also had this problem with SonicStage 3.4 and gave up in the end. I have the latest version of DirectX and all necessary drivers for my PC, can anyone help???Welcome to MiniDisc !from which region are you trying to download SonicStage ? Link to comment Share on other sites More sharing options...
takuhii Posted June 1, 2006 Report Share Posted June 1, 2006 stuge said: Welcome to MiniDisc !from which region are you trying to download SonicStage ?Thank you for the warm welcome. I'm trying to download the European version. Problem is I had exactly the same problem with the 3.4 version of SonicStage... Link to comment Share on other sites More sharing options...
danielbb90 Posted June 1, 2006 Report Share Posted June 1, 2006 takuhii said: Hi,I don't know if anyone else has been having the same problem, but I cannot get the web installer version of SonicStage 4.0 to install properly. It seems to have a problem with the actual SonicStage installtion bit, everything else install fine, it terminates the installation JUST before the add-on is installed, if I re-start the installtion it re-installs SonicStage and the Add-on, but doesn't generate ANY start menu options, and if I try to execute SonicStage from Windows Explorer it just sits there and doesn't open. I also had this problem with SonicStage 3.4 and gave up in the end. I have the latest version of DirectX and all necessary drivers for my PC, can anyone help???All I can say is post this in the Software help board.You have more chance of getting answers! Link to comment Share on other sites More sharing options...
Hironiemus Posted June 2, 2006 Report Share Posted June 2, 2006 stuge said: Welcome to MiniDisc !wait for sometime ..MFDC full installer will be available soonHow about putting the Installer that comes with the Player off it's CD and then online? takuhii said: Hi,I don't know if anyone else has been having the same problem, but I cannot get the web installer version of SonicStage 4.0 to install properly. It seems to have a problem with the actual SonicStage installtion bit, everything else install fine, it terminates the installation JUST before the add-on is installed, if I re-start the installtion it re-installs SonicStage and the Add-on, but doesn't generate ANY start menu options, and if I try to execute SonicStage from Windows Explorer it just sits there and doesn't open. I also had this problem with SonicStage 3.4 and gave up in the end. I have the latest version of DirectX and all necessary drivers for my PC, can anyone help???Once I also had a problem installing SonicStage (It might have even been OpenMG Jukebox). I believe it was when I wanted to update my Computer crashed during installation. When I rebooted my Computer I could neither install anymore nor uninstall. The problem remained until I went to the registry deleting all entries referring to Sony/Sonicstage manually. (It took my about 2 or 3 hours ) But after that procedure the installation worked flawlessly. So this is what you could do:- Uninstall via System Settings \ Software- Searching for Remaining Folders/Files of Sonicstage (Program Files\Sony, Settings and Documents\All Users\Application Data\SonicStage, Settings and Documents\"your username"\Application Data\SonicStage; the folder "Application Data" is usually hidden. There might be some other folders, these are just the ones that came to my mind; use the search function in Windows Explorer)- Go to the registry ( "Start" -> "Run" -> "regedit") and search for remaining entries/subgroups containing the word Sony (use the search function "Ctrl" + "F").But be aware: You could damage your Windows Installation if you delete the false entries. But if you have no other Sony Hardware/Software installed nor do you own a Sony Computer you should have no problem finding the right registry keys to delete.I'm sorry If not all the commands and folder names are right but my Windows Installation is German therefore I could only guess them.I hope I this helps you anyway if not someone comes up with an easier solution.Good Luck Link to comment Share on other sites More sharing options...
danielbb90 Posted June 2, 2006 Report Share Posted June 2, 2006 Hironiemus said: How about putting the Installer that comes with the Player off it's CD and then online?the iso or the exe? Link to comment Share on other sites More sharing options...
Avrin Posted June 2, 2006 Report Share Posted June 2, 2006 (edited) stuge said: It cannot happen until Sony upgrade the firmwares of Hi-MD walkman but i think they will never do that Did we need firmware upgrades for 352 or 192, when these were introduced? No!I am 99% positive that all current Hi-MD players will be perfectly happy with any ATRAC3plus bitrate available in SonicStage, if only transfers were allowed. Maybe even with ATRAC Advanced Lossless. Edited June 2, 2006 by Avrin Link to comment Share on other sites More sharing options...
Stuge Posted June 2, 2006 Report Share Posted June 2, 2006 (edited) Avrin said: Did we need firmware upgrades for 352 or 192, when these were introduced? No!I am 99% positive that all current Hi-MD players will be perfectly happy with any ATRAC3plus bitrate available in SonicStage, if only transfers were allowed. Maybe even with ATRAC Advanced Lossless.Transfers are not allowed b`coz these players(Hi-Md) are not compatible with it . Edited June 2, 2006 by stuge Link to comment Share on other sites More sharing options...
danielbb90 Posted June 2, 2006 Report Share Posted June 2, 2006 (edited) Avrin said: Maybe even with ATRAC Advanced Lossless.If it is TRUE 'Atrac' lossless (uses the same compressing method as the lossy codec - besides the loosing quality part) you would think it should work as a high vbr atrac3(plus) file? Edited June 2, 2006 by danielbb90 Link to comment Share on other sites More sharing options...
Sparky191 Posted June 2, 2006 Report Share Posted June 2, 2006 I guess its limted by whats on whats on the HiMD firmware. Link to comment Share on other sites More sharing options...
Avrin Posted June 2, 2006 Report Share Posted June 2, 2006 (edited) stuge said: Transfers are not allowed b`coz these players(Hi-Md) are not compatible with it .Then tell me please, why 192 and 352 were not allowed, and then suddenly became allowed? Without ANY firmware change! Edited June 2, 2006 by Avrin Link to comment Share on other sites More sharing options...
yoda_143 Posted June 2, 2006 Report Share Posted June 2, 2006 Any word on an offline installer yet? Link to comment Share on other sites More sharing options...
Sparky191 Posted June 2, 2006 Report Share Posted June 2, 2006 Avrin said: Did we need firmware upgrades for 352 or 192, when these were introduced? No!I am 99% positive that all current Hi-MD players will be perfectly happy with any ATRAC3plus bitrate available in SonicStage, if only transfers were allowed. Maybe even with ATRAC Advanced Lossless.On reflection I see your point. The decoders obviously in firmware. As long as its not been hardcoded for only specific bitrates you'd thing any bitrate would be possible. While I don't see the need for a huge range of bitrates, its an added "feature" that theres no good reason not to take advantage of. While a player/recorder with cheap 2GB disks, lossless and gapless would great. I think they'd be better putting recording functionality on their HD players though. Link to comment Share on other sites More sharing options...
Avrin Posted June 2, 2006 Report Share Posted June 2, 2006 (edited) Well, I know some things exactly (after having stared at the screen covered all over with HEX code). The bitrates ARE hard-coded in SS, SB, and drivers. I even know the HEX values for them. Not that I'm going to disclose all of them, but:80 BB 00 00 - 48 kbps,00 FA 00 00 - 64 kbps,00 E8 03 00 - 256 kbps,and there are others (such as 00 71 02 00).If you perform a careful search in the registry of you computer, you will find (at least) some of these values (I still don't understand why they write them to the registry. No opportunities discovered yet. Though SS34 did behave somewhat indecently (from the SONY point of view) when controlled from the registry - means it reads from there, but is unable to fully comprehend what is commanded, and then overwrites the stuff again). The programs, and drivers, are really hackable, but due to the ([CENSORED]) way they are written, no decent hacker will spend their time on that. And do we have a decent hacker, who is also an MD addict?SONY, please, don't pay attention to this. Edited June 2, 2006 by Avrin Link to comment Share on other sites More sharing options...
robin726 Posted June 3, 2006 Report Share Posted June 3, 2006 nathantw666 said: Nothing against you, but your statement made me smile because it reminded me of when CD's first came out. People that preferred listening to vinyl would say things like "I can't stand listening to CD's because it sounds like a machine gun going off." They were referring to the pits that carry the music that the laser reads. I wonder what those people listen to now days since almost all music comes on CD?Just a question: did you listen to CDs when they first came out? I did, and on some high-end gear too. It sounded like crap. Second-generation units sounded better, and third generation got to the point where I could actually imagine buying a CD. But still, many discs themselves were made very poorly (masters used same as for vinyl, etc.). I saw a great demo where some error diagnostic equipment was hooked up to the output of a CD player. After each play the error rate went up. And that was on a Nakamichi (IIRC) deck, not one I could even remotely afford.MP3 encoders too sounded very poor at first. I remember actually spending good money to buy one "back in the day". Today LAME blows it out of the water.Not all sound is equal.Sorry though, this is all OT. ;-) Link to comment Share on other sites More sharing options...
Avrin Posted June 3, 2006 Report Share Posted June 3, 2006 robin726 said: Just a question: did you listen to CDs when they first came out? I did, and on some high-end gear too. It sounded like crap. Second-generation units sounded better, and third generation got to the point where I could actually imagine buying a CD. But still, many discs themselves were made very poorly (masters used same as for vinyl, etc.). I saw a great demo where some error diagnostic equipment was hooked up to the output of a CD player. After each play the error rate went up. And that was on a Nakamichi (IIRC) deck, not one I could even remotely afford.Now I like it. No, I mean, I realy do!!! Link to comment Share on other sites More sharing options...
ynos Posted June 4, 2006 Report Share Posted June 4, 2006 I guess this is not worth for me to install v4.0 right now I've got v3.4 and works fine for me. Link to comment Share on other sites More sharing options...
yoda_143 Posted June 4, 2006 Report Share Posted June 4, 2006 ynos said: I guess this is not worth for me to install v4.0 right now I've got v3.4 and works fine for me. Same here.I'm gonna wait till there's an offline installer, since my home connection is very unstable. Link to comment Share on other sites More sharing options...
danielbb90 Posted June 4, 2006 Report Share Posted June 4, 2006 yoda_143 said: I'm gonna wait till there's an offline installer, since my home connection is very unstable.Either way, It still has to be downloaded! Link to comment Share on other sites More sharing options...
The Low Volta Posted June 4, 2006 Report Share Posted June 4, 2006 yes, but not necessarily on the unstable home-connection and at least there's no chance of timing-out while installing and thus ruining the installation (or even worse some registry stuff) Link to comment Share on other sites More sharing options...
anont Posted June 8, 2006 Report Share Posted June 8, 2006 nathantw666 said: Nothing against you, but your statement made me smile because it reminded me of when CD's first came out. People that preferred listening to vinyl would say things like "I can't stand listening to CD's because it sounds like a machine gun going off." They were referring to the pits that carry the music that the laser reads. I wonder what those people listen to now days since almost all music comes on CD?People also said that cassette tapes don't sound very good - and were right. At some point audio quality does matter. If it didn't why would we be spending so much money on digital music players with only 1 GB storage? Link to comment Share on other sites More sharing options...
Avrin Posted June 8, 2006 Report Share Posted June 8, 2006 Some more staring at HEX code, and performing comparative analysis revealed the following sad information:Transferring files with different bitrates to HiMD requires different routines (not a single routine with the bit rate as a parameter). SS30 had routines for all bitrates it officially supported, and also for 192 and 352kbps. The latter two were implemented, but not enabled. It also had a routine for transferring 32 kbps ATRAC3plus files. This one was also disabled. And my RH10 revealed (under torture) that it knows that there exists such a thing as ATRAC3plus@32 kbps.The 192 and 352 kbps routines were both enabled by the time SS34 came out (I did not check other versions). SS40 also has these two routines enabled, but no longer contains any traces of 32 kbps.So it seems that SONY planned the introduction of 192 and 352 kbps for HiMD for some time. But now it no longer plans any new bitrates. Simply hacking the program will not make it possible to transfer 96, 128, 160, or 320 kbps, because of the lack of the corresponding routines.What else may be of interest, is that there are traces of 11, 22, and 44 kbps in the code. And 48 kbps does not completely look like it belongs to the ATRAC3plus family (while 32 kbps did). Probably SONY initially planned 32 kbps, but the sound of it was so horrible, that they decided to use 48 kbps instead, thinking that it sounds better. Link to comment Share on other sites More sharing options...
turezky Posted June 12, 2006 Report Share Posted June 12, 2006 any news of offline version yet? Link to comment Share on other sites More sharing options...
Richard Posted June 12, 2006 Report Share Posted June 12, 2006 Some interesting findings Avrin - nice detective work! Link to comment Share on other sites More sharing options...
Christopher Posted June 12, 2006 Author Report Share Posted June 12, 2006 Soon, thank you for your patience. turezky said: any news of offline version yet? Link to comment Share on other sites More sharing options...
danielbb90 Posted June 12, 2006 Report Share Posted June 12, 2006 (edited) Avrin said: Some more staring at HEX code, and performing comparative analysis revealed the following sad information:Transferring files with different bitrates to HiMD requires different routines (not a single routine with the bit rate as a parameter). SS30 had routines for all bitrates it officially supported, and also for 192 and 352kbps. The latter two were implemented, but not enabled. It also had a routine for transferring 32 kbps ATRAC3plus files. This one was also disabled. And my RH10 revealed (under torture) that it knows that there exists such a thing as ATRAC3plus@32 kbps.The 192 and 352 kbps routines were both enabled by the time SS34 came out (I did not check other versions). SS40 also has these two routines enabled, but no longer contains any traces of 32 kbps.So it seems that SONY planned the introduction of 192 and 352 kbps for HiMD for some time. But now it no longer plans any new bitrates. Simply hacking the program will not make it possible to transfer 96, 128, 160, or 320 kbps, because of the lack of the corresponding routines.What else may be of interest, is that there are traces of 11, 22, and 44 kbps in the code. And 48 kbps does not completely look like it belongs to the ATRAC3plus family (while 32 kbps did). Probably SONY initially planned 32 kbps, but the sound of it was so horrible, that they decided to use 48 kbps instead, thinking that it sounds better.Great findings!that 32kbps, I want for speach on my Hi-MD player...Do you think they will ever allow it? I've been wanting somethin like that for a while now! Edited June 12, 2006 by danielbb90 Link to comment Share on other sites More sharing options...
jimmyuk Posted June 13, 2006 Report Share Posted June 13, 2006 Once SS40 is installed, can we uninstall Connect? The thought of that monstrosity still sitting on my hard drive deeply offends me for some reason. Link to comment Share on other sites More sharing options...
Stuge Posted June 14, 2006 Report Share Posted June 14, 2006 jimmyuk said: Once SS40 is installed, can we uninstall Connect? Yes Link to comment Share on other sites More sharing options...
garyc Posted June 14, 2006 Report Share Posted June 14, 2006 looks good Link to comment Share on other sites More sharing options...
riotshield Posted June 14, 2006 Report Share Posted June 14, 2006 stuge said: YesHow? Link to comment Share on other sites More sharing options...
shione Posted June 14, 2006 Report Share Posted June 14, 2006 (edited) <strike>Walkman -a Whats that? The early model mindiscs? </strike>Nevermind. Just did some testing and it isn't what I was hoping it would be. oh well. the hardware limitation still stands. hahaConverted some mp3s to my himd and it feels like the conversion process is faster in this version than 3.3.Does anyone know which .exe's can be disabled (read erased) and still have sonic stage functioning? All I use it for is to download + convert music to my walkman. ssaad.exe is one. anyone know any others?Also the program stil has the annoying habit of adding ssaad.exe to your startup list even after you remove it. Cant wait till the bug in spybot is fixed so it cannot silently deny sonicstage access from adding itself back. Edited June 14, 2006 by shione Link to comment Share on other sites More sharing options...
shione Posted June 14, 2006 Report Share Posted June 14, 2006 jimmyuk said: Once SS40 is installed, can we uninstall Connect? The thought of that monstrosity still sitting on my hard drive deeply offends me for some reason.look in add/remove programs. if its not there, you could uninstall the whole sonic stage package and then run the asia/pacific version of the online installer. I can vouch from first hand experience that the asia/pacific version does not have connect. It's 100% in English too. Link to comment Share on other sites More sharing options...
geed Posted June 19, 2006 Report Share Posted June 19, 2006 well ive tried ss 4 on windows 2003 and i get transfer errors =[ hopefully a workaround will come about since 2003 is my fav os! <3 :fingers crossed: Link to comment Share on other sites More sharing options...
Sparky191 Posted June 19, 2006 Report Share Posted June 19, 2006 Why do you run a server OS? Link to comment Share on other sites More sharing options...
Tunster Posted June 19, 2006 Report Share Posted June 19, 2006 geed said: well ive tried ss 4 on windows 2003 and i get transfer errors =[ hopefully a workaround will come about since 2003 is my fav os! <3 :fingers crossed:Why on earth is Windows 2003 your fav OS!? It's a server OS, not for general use for public use. Thats probably why it doesn't work with SS4.0. I'd recommend you reinstall to XP. Can't see you getting any benefits from Windows Server 2003 . Link to comment Share on other sites More sharing options...
singercrescendo Posted June 23, 2006 Report Share Posted June 23, 2006 it says the offline installer is available in 2 weeks. When was this writtern?hope its here soon cos ALL my music is on an offline computer. Link to comment Share on other sites More sharing options...
mariocel Posted June 25, 2006 Report Share Posted June 25, 2006 Well I downloaded the 3.4 version like two months ago. I wonder if it´s worth to download this newer version. Could somebody help me? Any good reasons? I own a RH-910. And hey, what the hell means CP? Thanks. Link to comment Share on other sites More sharing options...
tommypeters Posted June 28, 2006 Report Share Posted June 28, 2006 No, with a Hi-MD I can't see any reason for upgrading from 3.4 to 4.0. Link to comment Share on other sites More sharing options...
Sparky191 Posted June 28, 2006 Report Share Posted June 28, 2006 I assume CP is for "connect player" which used to be used with the MP3 players. Link to comment Share on other sites More sharing options...
mariocel Posted June 30, 2006 Report Share Posted June 30, 2006 It seemed so.Thanks for the info! Link to comment Share on other sites More sharing options...
